ᐅ How stable are Ikea Pax wardrobes on uneven or unstable floors?
Created on: 23 Apr 2018 10:12
Ruhiron
Hello everyone, I have an important question that’s been on my mind: How stable are Ikea Pax wardrobes when placed on an uneven or slightly unstable floor? I’m planning to install a Pax wardrobe at home, but the floor isn’t perfectly level and consists of old wooden floorboards that have some slight springiness in certain areas. I’m wondering if this could affect the wardrobe’s stability or safety, especially when it’s fully loaded. Are there any particular risks or recommended precautions to prevent accidents? Thanks for your advice!
Johnnybe
23 Apr 2018 16:42
Important: Never leave a Pax wardrobe unsecured, even if the floor appears somewhat stable. Always firmly screw it to the wall, especially on uneven floors!
gekira
24 Apr 2018 09:29
From a technical perspective, the greatest safety concern is the risk of tipping, which significantly increases on unstable or springy foundations.
- Therefore, securing the unit to the wall according to the installation instructions is essential.
- Additionally, the floor area where the cabinet stands should be as stable and level as possible. A base plate made of strong material can help ensure this.
- It is also important that the load inside the cabinet is evenly distributed to avoid localized overloads.
An uneven or flexible floor is thus primarily a challenge during installation rather than a typical weakness of the Pax construction itself.
fasau
24 Apr 2018 14:11
I find this topic really important! I once faced a similar situation with an old wooden floor. My solution was to level the floor area using a sturdy chipboard panel and then properly secure the cabinet to the wall. Since then, it has been rock solid, even though the floor isn’t perfect!
So don’t worry – with a bit of effort, you can definitely ensure safety! You just have to stay persistent and follow the recommended safety measures. Good luck with your project!
O
ONRONA
25 Apr 2018 08:57
fasau schrieb:
I once had a similar situation with an old wooden floor. My solution was to level the floor area using a sturdy chipboard and then properly secure the cabinet to the wall.
That’s a very practical tip! Such pragmatic approaches are often the best way to address structural issues, especially when there is a risk of direct floor instability.
Additionally, I would recommend regularly checking the cabinet feet to detect any settling or material fatigue early.
