ᐅ How stable are IKEA Brimnes wardrobes when fully loaded?
Created on: 1 Jun 2020 08:17
Bufiman
Hello everyone, I would like to start a discussion on the topic "How stable are IKEA Brimnes cabinets when fully loaded?" Specifically, I am interested in how these cabinets perform in everyday use when completely filled with heavy items, such as heavy books, kitchen utensils, or other household goods. Are the cabinets still safe, especially regarding their stability and sturdiness? Are there any experiences on whether they warp over time or if there are issues with the load capacity of the shelves? I look forward to your informed opinions or tips on how to ensure these pieces of furniture remain durable even when used to their full capacity.
Surela
1 Jun 2020 19:14
kogudra schrieb:
The use of the supplied back panel also contributes to stability – it reinforces the frame and prevents twisting.
Exactly, this aspect is often underestimated in many instructions. The back panel acts as diagonal bracing in structural terms and minimizes warping of the panel under load. Without the back panel, the side walls can bend. It would also be interesting to know if Bufiman plans to modify or rebuild the furniture piece to increase its load-bearing capacity.
ladali
2 Jun 2020 07:55
In addition to securing the shelves to the wall and using the back panel, it is essential to follow the manufacturer's specifications regarding the maximum weight per shelf. The Brimnes cabinet has a load limit of about 15 kilograms (33 pounds) per shelf, and since the shelves are made of particleboard without real reinforcement, they can bend more than solid wood shelves. Simply put:
- Avoid stacking too many heavy items in one place
- Distribute weight evenly
- If in doubt, insert an additional wooden board inside as reinforcement
This prevents damage and ensures a long-lasting cabinet.
GEKAU51
2 Jun 2020 12:33
I think these IKEA cabinets are sometimes a bit overrated. Sure, they are practical and affordable, no question about that, but when we talk about 'fully loaded,' we shouldn’t pretend these pieces are designed for industrial-level weights. If you need to store heavy loads regularly, you shouldn’t use particleboard shelves that will bend over time under continuous weight. IKEA has made compromises here – which doesn’t mean the furniture is bad. But anyone looking for stability needs to approach this realistically and shouldn’t expect miracles.
Le_kin
2 Jun 2020 15:44
An additional consideration regarding stability: When looking more closely at the material properties of particleboard, it becomes clear that its tensile strength is relatively low. The core density is lower compared to solid wood, which leads to greater bending under load. For heavier loads, it is advisable to reinforce the shelves with additional bracing or metal brackets, or to install thicker shelves yourself. Furthermore, the distribution of the load is crucial: A concentrated heavy load (e.g., a heavy vase on a corner) causes more damage than the same weight evenly distributed across the center of the board. Therefore, it is recommended for the owner to:
- Distribute loads evenly
- Respect maximum load limits
- Secure the cabinet firmly to the wall
- Reinforce the cabinet internally if carrying particularly heavy loads
These are basic measures to prevent negative effects such as warping or instability.
Timofa
3 Jun 2020 09:18
GEKAU51 schrieb:
I think people sometimes overestimate these IKEA cabinets a bit too much.
There is some truth to that! 😉 IKEA furniture is designed for everyday use, not as heavy-duty storage for warehouses. Still, you get a lot of storage space for the price if you pack it smartly. The key, as mentioned, is not to constantly push the limits. “Fully loaded” is a flexible term here. My advice to everyone: better to leave some space and reorganize regularly rather than piling on weight the cabinet can’t support. That way, you’ll enjoy the furniture for a long time.
