ᐅ What is the best way to transport Ikea PAX units to prevent damage?
Created on: 18 Jul 2024 08:17
FowilfridF
Fowilfrid18 Jul 2024 08:17Hello everyone,
I am planning to transport an Ikea Pax wardrobe and want to avoid any damage as much as possible. Since the components are often quite large and sometimes delicate, I am interested in how you approach secure transportation.
What preparations do you find useful to prevent scratches or deformations?
Do you disassemble the wardrobe parts, and if so, what is the best way to do this?
Which materials do you use for padding, and do you pay special attention to protecting the corner edges?
Do you have any tips for loading in a van or car to ensure everything arrives safely?
I look forward to your experiences and advice, so my Pax remains in good condition after the move.
Fowilfrid schrieb:
What preparation is advisable to prevent scratches or warping?Hey, I completely understand how important this is to you – I once had a case where, despite all precautions, unsightly scratches appeared on the surface. My advice: definitely remove all loose parts, especially the floors, and store small items in boxes, as they can easily shift and cause damage.
Fowilfrid schrieb:
Do you separate the cabinet units, and if so, what is the best way?Yes, I recommend disassembling the PAX units as much as possible: side panels and back panels (which are very fragile!) should be wrapped in protective film and transported flat. Load the large pieces upright and cushioned – this helps prevent warping.
Fowilfrid schrieb:
What materials do you use for padding, and do you protect the corners especially?For protection, I use foam boards or professional edge protectors. If those aren’t available, blankets and thick towels work too – but they need to be secured firmly. Corners are really critical as they dent easily.
Fowilfrid schrieb:
Do you have tips for loading in the van or car so everything arrives safely?Make sure the pieces cannot slip against each other; ropes or ratchet straps are helpful here. Place heavier items on the bottom and lighter ones on top or in between. I’ve also tried a little trick regarding humidity: back panels don’t like moisture, so dry transport conditions are preferable.
I hope this helps – a bit of planning beforehand really pays off to avoid problems.
Nathanaelk19 Jul 2024 10:21I’m happy to add some technical details about transporting the Ikea PAX.
First of all, it’s advisable to completely disassemble the wardrobe as much as possible. Keep in mind that the back panels are very delicate – they are usually made of thin hardboard and can easily bend or tear. Pack these flat and secure them firmly between two wooden boards or cardboard sheets to prevent pressure marks or bending during transport.
Side panels and doors should be protected with edge guards. Soft foam profiles work well because they adhere nicely to corners and are lightweight. If you don’t have edge protectors, you can wrap several layers of blankets or bubble wrap around the edges and secure them with masking tape or straps.
When transporting in a vehicle, careful securing is essential:
- Place large panels upright, not flat, to avoid deformation.
- Avoid stacking fragile parts on top of each other.
- Fill gaps with soft materials to prevent shifting.
Also, make sure no heavy objects are placed on top of the PAX wardrobe, especially not for extended periods, as this can cause the panels to bend.
One question for you: How are you transporting it? Rental van, private vehicle? That might affect how you approach it.
Fowilfrid19 Jul 2024 11:18Nathanaelk schrieb:
One question for you: How are you transporting? Rental van, private vehicle?Thank you for your detailed tips! I will use a rented van. Therefore, I need the best possible securing method since I don’t know how often it will be moved during transport. I will take your advice regarding the rear panels and edge protectors into account.
How durable are the original Ikea screws with frequent assembly and disassembly? Or a more important question: Is it better to buy new screws? Can the screws withstand the load during transport, or would it be better to partially disassemble the parts to reduce stress?
The original Ikea screws are generally designed for multiple assemblies, but frequent assembling and disassembling can eventually wear out the threads in the wooden panels.
It is best to completely disassemble the cabinet for transport to reduce stress on the screws. If you are worried about losing parts, keep spare screws ready or purchase a small set of matching replacement parts.
For transport in a rental van, I recommend
- carefully padding all parts before loading,
- always storing the back panels flat,
- positioning the large parts upright,
- using strong straps to secure everything,
- and choosing only dry weather, as moisture can damage the back panels.
If you don’t want to assemble and disassemble frequently, it’s better to take the furniture apart thoroughly once and secure it properly, rather than transporting fully assembled components—this is often a risk factor for scratches or damage.
