ᐅ How should MALM furniture be stored properly during extended periods of non-use?
Created on: 13 Nov 2022 09:17
magama
I am planning not to use my IKEA Malm furniture for several months because we are moving soon, and the new place will not be ready until later. My specific question is: How should Malm furniture be stored properly during long periods of non-use to avoid potential damage such as warping, moisture damage, or color changes?
Are there any proven methods regarding the type of storage (standing or lying down), protection against moisture, optimal room temperature, or packaging? I am also interested in whether it is better to disassemble the furniture or store it fully assembled.
I am looking forward to your experiences and tips!
Kinbu
13 Nov 2022 12:11
Regarding your question about a product: For the painted surfaces of the Malm furniture, I recommend a mild furniture care oil or light polishing wax without solvents.
Many customers report good experiences with products such as water-based beeswax pastes or special furniture oils for coated surfaces that do not contain silicones. Apply sparingly and allow to absorb well.
It is important to test beforehand on an inconspicuous spot to rule out any color changes.
TEOZAR
14 Nov 2022 08:52
I would like to add that you should maintain a consistent humidity level during storage. Ideally, it should not exceed 60%, as higher values can cause swelling in MDF and decorative foil.
If you don’t have an ideal storage space, a dehumidifier can help. However, the air should not be too dry, as this can lead to cracking. A room climate average of around 50% is therefore optimal.
Ellis
14 Nov 2022 09:38
TEOZAR schrieb:
An indoor humidity average of around 50% is therefore optimal.
I completely agree. Moisture protection is usually the most important factor.
magama
14 Nov 2022 10:45
Ellis schrieb:
Moisture protection is usually the most important thing.
That makes sense, thank you very much!
Is there a risk that I should somehow preserve or protect the screws and fasteners from rust during long-term storage? I am storing them in a rented garage that is not fully climate-controlled but tends to be dry in winter.
Would it be advisable to treat the metal parts separately or wrap them in special material?
TEOZAR
15 Nov 2022 07:34
You can store metal parts in small bags with silica gel packets.
This helps prevent rust. Alternatively, greaseproof paper is suitable because it is breathable and does not trap moisture.
You can also use light rust protection sprays that do not leave greasy residues. However, you should remove them thoroughly before assembly.
reni45
16 Nov 2022 17:19
Disassemble and store dry. Collect screws together in a bag.
Do not store directly on the floor; ideally place on wooden slats or cardboard.
That is sufficient.
