ᐅ How secure are Ikea Metod wall cabinets under load?
Created on: 18 Aug 2020 08:27
jesin0
jesin0
18 Aug 2020 08:27
I am currently planning to equip my kitchen with Ikea Metod wall cabinets, but I have an important question that has not yet been fully clarified: How secure are these Metod wall cabinets under load? Specifically, I am interested in how much weight the cabinets can typically hold without compromising stability or causing the mounting hardware to pull out from the wall.
I am not only thinking about regular kitchen appliances or storage jars, but also occasional heavier loads, for example, if something heavier is stored in the cabinet or if the door is accidentally bumped. Additionally, it would be helpful to get advice on the optimal installation, since the mounting system is often considered the weakest point.
Are there practical experiences? I look forward to reliable feedback, including any official manufacturer guidelines and recommendations on what to avoid. Thank you!
JORDON
18 Aug 2020 09:15
Hello jesin0,
Your question is very important, as no one wants an unpleasant surprise on the kitchen wall later on 😉. Ikea officially specifies a maximum load capacity for Metod wall cabinets, which is usually around 20 kilograms (44 pounds) per cabinet, provided the installation instructions are correctly followed.
The main concern is often the wall attachment, because wires, screws, and anchors need to be chosen according to the wall material.
From my own experience, if you use the supplied screws and securely embed them in the masonry or into the wall anchors, the cabinets hold quite reliably.
Of course, you should avoid overloading the cabinets or pulling on them uncontrollably, but for normal household use, they are sufficiently stable.
My advice: For heavier loads, it’s better to use additional backing plates or wall reinforcements, then heavier pantry items or cookware will be no problem 👍.
Roberta
18 Aug 2020 09:42
The maximum load capacity is approximately 20 kg (44 lbs) per wall cabinet, according to Ikea. Proper installation with suitable wall anchors is essential. For drywall or plasterboard walls, be sure to use special hollow wall anchors.
nonere
18 Aug 2020 10:03
Regarding the load capacity of the Ikea Metod wall cabinets, the following can be summarized:
- The official maximum load is approximately 20 kg (44 lbs) per cabinet.
- This specification refers to proper wall mounting using the original fixing elements.
- Screw fasteners must be anchored in load-bearing material (solid wall, wooden stud).
- In drywall without studs, stability can only be ensured by using appropriate special anchors.
Overloading or incorrect installation can quickly lead to failure.
It is recommended to check the wall substrate before installation and to use suitable anchors. Even load distribution inside the cabinet is also essential.
jesin0
19 Aug 2020 07:57
JORDON schrieb:
Ikea officially states a maximum load capacity for Metod wall cabinets, which is usually around 20 kilograms per cabinet when the installation instructions are properly followed.
That’s a useful reference point, thanks! My question is how critical the mounting actually is. Are the included wall plugs/anchors really suitable for all types of walls, or is it often recommended to purchase additional materials?
I live in an older building with mixed wall constructions – partly solid and partly with a thin brick veneer. Would it be better to use a professional mounting method in this case? Does anyone know if Ikea generally uses more or less standard fixings and how their quality is rated?
Rodolfo
19 Aug 2020 09:28
jesin0 schrieb:
I wonder how uncritical the mounting actually is. Are the included anchors/drivers really suitable for all wall types, or is it often recommended to buy extra materials?
The screws and anchors provided by Ikea are usually standard metal anchors designed for solid concrete or brick walls. For lightweight walls, such as drywall or mixed old construction walls with cavities, these anchors are not ideal.
In such cases, it is advisable to use appropriate cavity anchors or other specific fasteners. There is no general rule that applies to “all wall types,” as wall construction can vary greatly.
It is also important to use at least two anchors per cabinet and to distribute the load evenly. For added safety, professional-grade mounting anchors or even specialized brackets designed for higher load capacities can be purchased.
