I would like to start a discussion on the topic: “How satisfied are you with the quality of IKEA Brimnes?” The furniture range may not be groundbreaking in terms of design, but it often scores well for its value for money. I am especially interested in your assessment of the material quality, workmanship, and durability—particularly for frequently used pieces such as cabinets or beds.
Do you have any experience with the load-bearing capacity of the drawers, the stability of the carcasses, or any assembly issues? I would also like to know if the surface is prone to scratches or wear and how the product holds up after long-term use.
I would really appreciate it if you could share your opinions and experiences in as much detail as possible to help create a clearer overall picture. Thanks in advance to everyone who takes the time to provide detailed answers!
The topic of IKEA BRIMNES and its quality definitely deserves a detailed look. I have been using several pieces of furniture from this series, especially wardrobes and beds, for about three years and can provide a nuanced evaluation.
Material components:
- The carcasses are mostly made of particleboard with a foil coating. This is not necessarily a dealbreaker in terms of quality, but it is the most vulnerable part of the construction.
- The thickness of the boards is relatively thin, which affects stability when the furniture is frequently moved or rearranged.
Workmanship and assembly:
- The drilling is mostly precise, which makes assembly easier, although the instructions are sometimes a bit confusing.
- The connecting fittings (cam locks) can be problematic at times, as they are easily damaged if not handled carefully.
Use and durability:
- Drawers usually operate smoothly, but after heavy use they can become a bit loose or squeaky, especially if the screws loosen over time.
- The foil coating is sensitive to scratches and is not very easy to repair.
Overall, I would say the quality of BRIMNES is solid for the price but by no means premium or particularly durable. It is more suitable for beginners or budget-conscious buyers who do not expect heavy use from their furniture.
By the way, I am curious how you protect the surface in everyday use when your wardrobes are subjected to rather rough conditions. Do you prefer using protective mats, or do you simply handle the furniture with extra care?
Use and durability:
Palenar schrieb:
The film coating is sensitive to scratches and not very easy to repair.I can confirm that; the film surface is the biggest drawback of the BRIMNES series. In my experience, it scratches relatively easily, especially when the furniture is frequently moved or comes into contact with sharp objects. Repairs are indeed difficult and usually only superficial.
In my view, it’s worth protecting the furniture in exposed areas with furniture padding film or similar protective material, especially the edges. I also recommend regularly retightening the screws after assembly, as this makes the drawers and carcasses somewhat more stable.
I’ve had very good results with adding glue at the wooden joints to increase stability, if you’re comfortable with that kind of DIY. Otherwise, I see BRIMNES more as an affordable option for someone who doesn’t plan heavy use or long-term ownership.
warrenka5723 Nov 2024 17:38Kapepu schrieb:
I’m especially interested in your assessment of the material quality, workmanship, and durability—especially for frequently used furniture like cabinets or beds.I completely understand that these aspects are crucial for you. I used the BRIMNES wardrobe extensively for a while and had some issues with assembly and stability. I found the durability acceptable but not outstanding.
In my opinion, it’s important to be aware before purchasing that BRIMNES furniture is designed more for medium-term use—so if you want something flexible and affordable, it should work well. But if you’re planning for the long term, I would rather advise against this series; in my view, the material is a bit too lightweight.
I think it’s great that you’re asking here and giving it careful thought. Sometimes exchanging experiences helps a lot, especially with products you don’t buy very often. If you like, feel free to share how your decision turns out—we’re here to support you!
