ᐅ How stable are IKEA Brimnes furniture pieces during vibrations or shaking?
Created on: 20 Apr 2017 14:23
KedibeHello everyone, I am looking into how stable IKEA Brimnes furniture really is when exposed to vibrations. Specifically, I am interested in how sturdy these pieces are for use in homes with children or pets who often play roughly. My main concern is whether the materials and construction can withstand the stress from repeated minor shocks without becoming unstable or damaged quickly. Are there any practical experiences or specific advice regarding the build quality, stability, or safety aspects of Brimnes? It would be great if someone could share their assessment or relevant information!
Kedibe schrieb:
how safe the IKEA Brimnes furniture really is during vibrationsHello Kedibe! I find the Brimnes series really quite sturdy! I personally have a bed and a wardrobe from this range and can say they hold up well. Especially when everything is assembled correctly—meaning all screws are tightened properly and, if needed, the furniture is secured to the wall—they are very stable. Of course, it’s not solid wood furniture, but for everyday use, even with children, it is absolutely sufficient. Vibrations caused by playing or repeatedly opening the doors are hardly noticeable. So don’t worry, I consider Brimnes to be very safe furniture that can withstand a lot! Feel free to give it a try!
Pome60 schrieb:
Especially when everything is assembled correctly, with all screws tightened properly and, if necessary, the furniture fixed to the wall, they are really stable.This is an important point. IKEA furniture like the Brimnes series is mainly made of particleboard with a foil finish, so the joinery technique is crucial for stability. Vibrations, such as sudden shaking of shelves or a cabinet, can gradually widen the connection holes if the furniture is not properly secured.
The Brimnes series offers solid craftsmanship for its price range, but for frequent or stronger vibrations, securing it with wall anchors is definitely recommended. There is little reliable data on how these pieces respond to mild vibrations caused by children or pets, but the construction suggests moderate durability rather than extreme robustness.
In summary: stable, but not indestructible – wall anchoring is essential if the furniture is subject to frequent vibrations.
Hello Kedibe,
I would like to go into more detail on this topic because it seems important to me to thoroughly consider the safety of furniture like Brimnes.
IKEA mainly uses coated particleboard for Brimnes. These materials are generally stable for everyday use if processed correctly.
However, the furniture can only remain stable over time under vibrations—whether caused by playing children, pets, or small accidents—if
- the assembly is completed fully and correctly as instructed,
- all screws and dowels are regularly checked and tightened when necessary,
- it is secured to the wall (this greatly reduces the risk of tipping and falling).
The point about wall attachment is essential: Many IKEA assembly instructions explicitly emphasize the need for securing the furniture because the design alone is not intended to withstand increased vibrations based only on stability.
Although Brimnes uses relatively sturdy connectors, the risk of material fatigue due to repeated strong vibrations should not be underestimated. Especially with shelves that have moving parts or doors, the risk of connection elements loosening increases.
So, safety clearly depends on assembly and use. For households with a lot of activity (children, pets), I strongly recommend attaching the furniture to the wall and regularly checking the screws.
If you need more detailed information about proper attachment or damage, I am happy to help further.
Kedibe schrieb:
how safe the IKEA Brimnes furniture actually is during vibrationsThe key factors for the safety of Brimnes furniture under vibrations are both the material and the assembly.
The particle boards used are not designed for strong, continuous vibrations or loads, such as those encountered in vehicles or industrial environments. However, in residential settings, they are sufficiently durable if assembled correctly.
Vibrations caused by playing children or pets usually appear as impact loads and vibrations. Over time, these can create weak points due to loose fittings or joints if the furniture is not regularly maintained.
In practical terms, this means:
- Furniture must be secured to the wall according to the manufacturer’s instructions
- Screws and connections should be checked and tightened
- Furniture placed on a level, solid surface reduces tipping and swaying movements
Without these measures, frequent use involving regular vibrations can lead to deformation or loss of stability.
Therefore, regular inspections during use are highly recommended to ensure safety is maintained.
