ᐅ How quickly can IKEA PLATSA furniture be disassembled?
Created on: 3 Apr 2015 09:17
Debbieja
Debbieja
3 Apr 2015 09:17
I am currently looking into how quickly IKEA Platsa furniture, especially typical shelving units, can be disassembled. This question is for those who have practical experience with this: On average, how much time do you need to take these pieces apart? I am particularly interested in whether you use any special tricks or tools that significantly speed up the process, and if there are any tips to keep in mind to avoid damaging the furniture parts.
I know that the assembly instructions are usually clear, but disassembling sometimes seems trickier than assembling. I’m also curious whether the time required varies greatly depending on the size of the furniture and personal experience with furniture assembly.
Thanks in advance for your insights and experiences!
LENNAU
3 Apr 2015 09:42
Hello Debbieja,
First of all, I think your question is very well and clearly formulated, which definitely helps with the assessment.
In my experience, the time needed to disassemble PLATSA furniture strongly depends on how familiar you are with the system and whether you have the right tools at hand. Ideally, you need a cordless drill with the appropriate bit, which is much faster than using a standard screwdriver.
Typical screw connections and dowels can be loosened fairly quickly with some practice. For a medium-sized PLATSA shelving unit with 3-4 modules, I would estimate about 20 to 30 minutes – this includes carefully removing the back panel and individual shelves.
It is important that no one uses too much force to avoid damaging the furniture. For larger units, it helps to work in pairs to hold the piece securely and to gently remove, for example, the back panels.
If you like, I can also provide some special tips on how to more easily release the connection systems or which tools are truly useful.
Ryder35
3 Apr 2015 10:11
LENNAU schrieb:
Typical screw connections and dowels can be quickly loosened with a bit of practice.
Exactly, a good cordless drill is half the battle. Without the right tools, the process easily takes twice as long.
For a PLATSA unit, I usually allow 15 to 25 minutes if you do it regularly.
nausu
3 Apr 2015 11:03
to answer the question precisely about how quickly IKEA PLATSA furniture can be disassembled, a structured approach is helpful.
- Material type: PLATSA mainly uses particleboard with plastic fittings, which are not designed for excessive force. This means careful handling is essential.
- Tools: A Phillips screwdriver or, better, a cordless drill with torque control is required.
- Procedure: Remove the back panel, loosen the screws at the joints, lift out the shelves, separate the carcasses.
In terms of time, durations vary depending on the size and number of modules, but one module usually takes about 20 to 30 minutes if there is no damage and the person is experienced.
If you provide more details about the screw type or specific components, I can give you a more precise estimate.
Katau
4 Apr 2015 08:29
Debbieja schrieb:
I am also interested in whether the time estimates vary significantly depending on the size of the piece of furniture and how much personal experience one has with furniture assembly.
Yes, I can definitely confirm that. For small units with just a few shelves, half an hour is often enough, while larger combinations—especially when multiple components are connected—can take up to an hour.
Experience also plays a major role: those who regularly disassemble furniture quickly learn the weak points, such as where to be especially careful and which screw to loosen first to relieve tension. Beginners tend to work much more slowly and need to take their time to avoid damage. This is particularly important with PLATSA, as the parts can sometimes be quite thin and may tear easily.
Lenfa
4 Apr 2015 14:17
Katau schrieb:
Also noteworthy is the impact of experience
I would like to add that thorough planning before disassembly also saves time. If you gather all the screws in advance and sort the individual components logically, the process runs much more smoothly. I also recommend taking photos of the assembled unit before taking it apart.
Regarding tools: In my experience, investing in a good cordless drill with variable speed that is not too heavy is worthwhile.
As for timing: Disassembling a single PLATSA shelf typically takes about 20 to 40 minutes, depending on whether you work alone or with a partner and how often modules have already been assembled and put together beforehand.
Personally, I avoid forcibly pulling off the back panel and prefer to work bit by bit to prevent any damage.
If anyone is looking for specific tips, I’m happy to provide more detailed advice.
