ᐅ How quickly can Ikea PLATSA furniture be taken apart into individual pieces?
Created on: 28 Dec 2024 14:07
tanote
tanote
28 Dec 2024 14:07
I have a specific question about Ikea Platsa furniture and how long it takes to disassemble it: How quickly can a typical Platsa piece be completely taken apart?
Specifically, I am interested in the process of fully dismantling the unit, including removing all fasteners such as cam locks, dowels, or screws. I am generally familiar with furniture assembly and tools but want to estimate whether disassembling a medium-sized Platsa cabinet (approximately 2 meters (6 ft 7 in) tall and 1 meter (3 ft 3 in) wide) into individual parts can be done in 30 minutes, or if it usually takes around an hour or more.
I’m also curious about which factors affect the time required, such as the type of connectors, the presence of backing panels or doors, and whether certain tools (specialized tools, screwdriver bits, etc.) can significantly speed up the process.
I would appreciate any experiences, estimates, and tips on how to disassemble more efficiently.
lisku
28 Dec 2024 14:46
In general, PLATSA furniture can be disassembled quite quickly if you have the right tools.
- Release the cam connectors
- Unscrew the screws
For a medium-sized cabinet, I would recommend allowing between 40 and 60 minutes if you proceed in an organized manner.
Filippo
28 Dec 2024 17:23
The time required to disassemble a PLATSA piece of furniture depends greatly on several factors. First of all, the type of fasteners used is crucial. PLATSA mainly uses cam connectors, which are relatively easy to loosen if you have the right torque screwdriver or bit attachment. Usually, these can be undone in seconds per connector.
However, it is also important to note that the back panels are often fixed with small nails or staples that need to be removed before taking the furniture apart – this can noticeably slow down the disassembly, especially if the staples are firmly in place or if you don’t have the proper tool for prying them out.
Additionally, the type of doors (hinged or sliding) and the hardware used influence the time needed. For example, a sliding door can be more complex because the track systems have to be separated.
To give a rough estimate: for a medium-sized PLATSA module with simple doors and standard back panels, you should allow about 45 to 60 minutes if you are experienced. For a beginner, it could easily take 90 minutes.
Important: Are you working alone or do you have help? Two people are much more efficient for larger volumes, especially when handling the big panels.
What kind of tools have you been using so far? A cordless drill with the right bits can significantly reduce the time. Do you already have experience with PLATSA furniture? If you provide more details about your piece and your tools, I can give you more specific advice.
Jensson
29 Dec 2024 09:11
To complement this, here is a structured procedure and some tips to make disassembly more efficient:
1. First, remove all doors and drawers. Doors are often secured with small metal clips or bars—handle these carefully to avoid damage.
2. Then systematically loosen the cam connectors. It’s recommended to proceed in a circular pattern to maintain stability during disassembly and avoid weakening the structure too early.
3. Remove the back panel. A flat spatula or a nail puller works well here, allowing you to avoid applying excessive force.
4. Remove screws from the back or from the connectors.
Important tips:
- Use a cordless drill with variable speed and bit attachments for Phillips and flathead screws.
- If available, use a holder for construction staples or nails—this saves time when removing the back panel.
In terms of time, with an experienced workflow and the right tools, you can typically disassemble a medium-sized PLATSA wardrobe in about 40 to 50 minutes.
Following the correct order and avoiding force will reduce time and minimize the risk of damage.
flo-Theres
29 Dec 2024 12:53
A very important point that is often overlooked is stability. When dismantling a PLATSA piece of furniture, you should try not to fully destabilize the structure too early.
For example, if you loosen all the cam connectors at once, the furniture might tip over or deform uncontrollably, which makes disassembly take longer and increases the risk of damage.
Therefore, I recommend loosening certain areas one after the other and dismantling the piece step by step. This helps avoid unnecessary stress.
It is also advisable to check all the types of screws and connectors in advance to have the right tools ready – this saves a lot of time during disassembly.
Dilen
30 Dec 2024 08:38
Filippo schrieb:
What kind of tools have you been using so far? A cordless drill with the right bits can significantly reduce the time needed. Do you have any experience with PLATSA furniture? If you provide more details about your furniture and tools, I can offer more targeted advice.
That’s an important point. For disassembling PLATSA modules, I strongly recommend using a cordless drill with good torque control and different bit sizes (PH2 is standard).
Although the cam connectors are easy to loosen, they require the correct torque setting to avoid damage, which would make reassembly more difficult.
I have found that proper preparation (tools, a plan, maybe even an idea for arranging the parts) can cut the time needed in half. It’s also worthwhile to plan the sequence shortly beforehand and to consider the type of furniture in detail (components, doors, drawers, back panel).
How large is your PLATSA exactly? Are there any special parts that need to be known in advance?
