Hello Barbar!!
I would advise you to have your gas heating system serviced every year, similar to how you would service a car.
First of all, it gives you the assurance that everything is working properly. Secondly, the unit needs to be cleaned—combustion chambers, gas tightness, ignition, and so on.
The only maintenance you can safely do yourself is cleaning the exterior, such as dusting. Other than that, I wouldn't recommend doing anything yourself if you are not experienced. So, I suggest having a professional carry out the servicing.
Best regards.
Best regards.
Sibille schrieb:
Good morning,
I wouldn’t touch a gas heating system at all, because gas is a serious matter. You often hear about entire houses exploding just because someone tampered with the heating system.
See you, SibilleThis usually happens when people try to tap into the gas supply illegally because they can’t or don’t want to pay for it.
That’s what Lucky tells you.
