ᐅ How often do material defects occur with the Ikea BRIMNES furniture?
Created on: 11 Jul 2024 19:23
gaupau
gaupau
11 Jul 2024 19:23
I have a very specific question, as I am planning to get the Ikea Brimnes furniture system: How often do material defects occur with BRIMNES products?
I am particularly interested in the proportion of defects that are due to manufacturing faults, rather than improper handling during assembly or use. Are there any experiences or data regarding the durability and longevity of the materials used, especially concerning joints, edges, and coatings?
I ask because I do not want to carry out major repairs on my furniture and wonder if the BRIMNES series tends to have more issues compared to other comparable Ikea solutions. Reliable user feedback and, if possible, information about the quality of workmanship beyond usual customer reviews would be most helpful.
Looking forward to your insights and thanks in advance!
Nathanaelk
11 Jul 2024 21:47
gaupau schrieb:
How often do material damages occur with the BRIMNES products?
This is a very good and at the same time complex question. I will try to answer it as comprehensively as possible. Fundamentally, the BRIMNES series consists of particleboard composites with a melamine or laminate coating, which is a relatively cost-effective but also delicate material combination.
Material damage can mainly occur at the edges, such as chipping of the coating, cracks in the engineered wood due to moisture exposure, or screw connections loosening through use.
In various online forums and customer reviews, I have seen a damage rate of about 5-10%—which includes both assembly errors and material failure.
It is important to assemble the connections carefully according to the instructions to minimize stress within the material. Also, placing heavy loads in only one spot without support promotes material fatigue.
Background information that few people know: Ikea verifies their furniture in laboratory tests to ensure load capacity and surface hardness. Nevertheless, BRIMNES components are not designed for permanent heavy loads but rather for normal household use.
Question for you: What kind of loads are you planning? Is the furniture placed in a more humid environment? This makes a big difference for durability.
Lorukeo
12 Jul 2024 08:14
For an objective assessment: Ikea BRIMNES furniture is mainly made from coated particleboard or MDF with a decorative laminate, which is cost-effective and visually appealing but naturally comes with some limitations regarding durability.
The material defects that occur are mostly focused on:
- Chipping at edges and corners
- Swelling of the panels due to moisture exposure
- Cracking or tearing out of holes for fasteners
It is not possible to provide an exact percentage of how often these defects occur, as Ikea does not publish official defect statistics. However, user reports and forum comments suggest a moderate failure rate: around 7-12% of buyers experience some problems in the mentioned areas within the first 1-2 years.
In summary: With careful assembly and normal use, the durability is reasonable; however, rough handling or exposure to damp conditions significantly increases the risk of material damage.
My advice: Pay close attention to precise assembly, avoid excessive point loads on unsupported surfaces, and ideally do not place furniture directly against damp walls.
likuken
13 Jul 2024 11:09
Nathanaelk schrieb:
Material damage mainly occurs at the edges, such as chipping of the coating, cracks in the engineered wood caused by moisture exposure, or screw connections that loosen during use.
Interesting, but honestly: for the price of BRIMNES, I don’t expect material quality that lasts forever. Of course, damage to edges and so on is normal when using particle board.
Lorukeo schrieb:
Experience from numerous user reports and forum comments suggests a moderate failure rate: about 7-12% of buyers encounter certain issues in the mentioned areas within the first 1-2 years.
That honestly doesn’t surprise me. Still, I wonder what the appeal is of buying furniture that you absolutely have to ‘handle carefully’ to avoid damage. Is this the future of furniture shopping? Cheap but fragile?
In the end, this shows what I believe is the major drawback of Ikea’s low-cost approach: stability and quality workmanship are secondary – the main goal is to sell a lot quickly. Anyone looking for real durability, in my opinion, needs to look elsewhere.
