ᐅ How much weight can a single BILLY shelf typically hold?
Created on: 29 May 2021 19:32
Ediga
Ediga
29 May 2021 19:32
I am planning to get a BILLY shelf from IKEA and would like to know exactly: How much weight can a single BILLY shelf board typically hold under normal use? I am especially interested in how much load each shelf board can roughly support without bending or getting damaged. Of course, this also depends on the width of the shelf and the type of load, but I would like to get a general idea.
Does anyone have experience with the maximum load capacity of individual BILLY shelf boards, ideally with real figures or official information from IKEA?
Thanks in advance for your feedback!
pakokla
29 May 2021 20:06
A single BILLY shelf can hold approximately 15 kg (33 lbs) evenly distributed. If you load the shelf evenly and avoid placing heavy weight in a concentrated spot, there should be no issues.
With larger spans, for example if the shelf is heavily sagging, the load capacity decreases.
Domau0
30 May 2021 08:47
Hello Ediga,
Your question about the average load capacity of a single BILLY shelf is very good, as there are often misunderstandings about this. IKEA officially states a load capacity of about 30 kilograms (66 pounds) for BILLY shelves, but this assumes the weight is evenly distributed and the shelf is properly assembled. In practice, however, it often looks different.
It is important to note that the thickness and material of the shelves (particleboard with veneer) as well as the length play a crucial role. Especially with the longer shelves (e.g., 80–90 cm (31–35 inches) wide), bending can begin if the load exceeds 15 kilograms (33 pounds) in the middle.
I have personally loaded shelves with about 20–25 kilograms (44–55 pounds), but the weight was not optimally distributed. If you want to place particularly heavy items like thick books, binders, or electronics on them, I recommend adding a center support or using shorter shelves.
Could you specify more precisely what purpose or type of items you plan to put on the shelves? That would help provide a more accurate assessment.
To simplify:
- Maximum load per shelf: ~30 kilograms (66 pounds) (official specification)
- Realistic load per shelf without bending is usually more like 10–20 kilograms (22–44 pounds)
- Span (shelf width) is a critical factor
Also, it would be helpful to know which shelf depth you are using, as that also affects stability.
PECLARISSA
30 May 2021 15:18
pakokla schrieb:
A single BILLY shelf can support about 15 kilograms (33 pounds) evenly distributed.
That sounds pretty solid, thanks for the quick reference! By the way, I also think that if someone treats a BILLY as a piece of art, it’s better to just leave it as is. But for everyday use, 15 kg (33 lbs) per shelf is really sufficient – my shelves are full of books, CDs, and some various finds, and everything holds up great.
Domau0 schrieb:
If you want to put particularly heavy items like thick books, binders, or electronics on it, I recommend adding a center support or using shorter shelves.
Yes, I can definitely confirm that – I installed a center support system after placing heavy collections on mine, and since then it’s been stable. So if you want more capacity, you can reinforce it, but for average use, the shelves are good enough as they are.
I also think a bit of trust in the construction doesn’t hurt – as long as you’re not stacking bricks 😉
Does anyone else have tips on how to use the shelves fully but still gently?
