ᐅ How much weight can MALM drawers hold?
Created on: 21 Mar 2015 08:17
Ni_us
Ni_us
21 Mar 2015 08:17
I am planning to furnish my home office with MALM dressers from IKEA and have not been able to find a clear statement on how much weight the MALM drawers can safely hold. My question is whether the drawers are generally designed to handle heavy loads, or if loading beyond a certain limit is likely to cause damage to the drawer slides or the drawer construction itself.
Can anyone provide a reliable assessment based on personal experience or expertise? I am particularly interested in whether all MALM drawers support the same weight capacity, or if there are differences depending on size or model. I want to make sure that heavy file folders and similar items can be stored without affecting the function or appearance.
Thank you very much for any helpful feedback!
flota
21 Mar 2015 10:03
Basically, MALM drawers are designed for typical household use and can usually support about 10-15 kg (22-33 lbs) per drawer, depending on the model and construction.
It is important not only to consider the weight on the drawer bottom but also to check the load capacity of the drawer slides. Excessive weight can lead to deformation or premature wear.
Additionally, weight should be distributed evenly to avoid localized overloading.
For very heavy loads such as file folders or tools, it is advisable not to fully load the drawers or alternatively to use stronger furniture or additional reinforcements.
CHRISTOP33
21 Mar 2015 11:46
flota schrieb:
Basically, MALM drawers are designed for regular household use and can typically hold around 10-15 kg (22-33 lbs) per drawer.
Yes, I can confirm that. I’ve used my MALM chest of drawers in the bedroom for clothes and a few cat books. 🙂
After 2 years, the drawers are still in great condition, and I’d say heavy loads like file folders could become a problem if you’re not careful.
Especially avoid opening them quickly while fully loaded, and they’ll last a long time. A bit of care for your furniture really pays off! 😉
Danabla
22 Mar 2015 09:58
For an accurate assessment of the maximum load capacity of MALM drawers, I recommend consulting the official IKEA documentation or their technical product information. Manufacturers usually specify the maximum load capacity for each drawer size and variant there.
Based on data from various sources and user experiences, the appropriate load capacity for standard MALM drawers ranges from about 12 to 15 kg (26 to 33 lbs). Higher loads increase the risk of material fatigue and functional issues, especially if the load is consistently applied.
The structural weak point in MALM and similar furniture is the drawer slides and runners, which typically use simple roller glides designed for light to medium loads.
If the drawer is to hold heavier items (such as file folders or tools), I therefore recommend either not overfilling the drawer, distributing the weight evenly, or opting for more robust systems from professional office furniture ranges. Alternatively, sometimes additional inner inserts or drawer organizers can be used to better support the load.
In conclusion: you should not expect to exceed 15 kg (33 lbs) per drawer if you want to maintain long-term functionality.
