Hello everyone, I have a question that has been on my mind for a while, and I would like to hear your opinions: How much heavy use—that is, heavy storage items or loads with high weight and frequent use—can the IKEA KALLAX shelf actually support without compromising its stability and durability in the long term?
I understand that KALLAX shelves are generally designed for moderate loads. However, in my work and hobby area, I often have heavy boxes and equipment that I would like to store in it. Therefore, I am particularly interested in whether there are load limits recommended by the manufacturer and if there are any experiences regarding how the shelf holds up over time under heavy weight—especially with frequent handling, loading and unloading, or moving the compartments.
Maybe someone also has tips on how to reinforce the shelf if you want to store a lot of weight in it. Thanks in advance for your opinions and suggestions!
toril schrieb:
13 kg per compartment (29 lbs)Thank you, that was exactly the information I was looking for.
Muso4 schrieb:
Are there people who have used the KALLAX for years with noticeably heavier loads and have experience with damage or sagging?That is also my biggest concern. Along with the question of how often you can load and unload the shelf without the material losing stability.
Do you perhaps have specific experience with shelves that were used long-term with loads significantly above the recommended values? When do stability issues usually start to occur?
cassandra schrieb:
Alternative solutions: metal shelving with higher load capacityThat is certainly an option, but the KALLAX has a certain charm and fits perfectly due to its dimensions. Therefore, I am also looking for tips on how to potentially reinforce it.
taule schrieb:
Do you have ... concrete experience with shelves that have been subjected to long-term loads significantly exceeding the recommended values?In practice, IKEA shelves like the KALLAX are indeed more durable than stated in the datasheets, but this always depends on how frequently they are used and how the load is distributed.
The material particle board tends to develop weak points, especially at the joints, when subjected to strong point loads. Moisture protection is also important, as particle board is sensitive to humidity.
Anyone handling heavy storage items frequently should make sure to regularly check all screws and fastenings.
Reinforcing the shelf by adding an MDF back panel or a metal frame can improve rigidity, but one should not expect miracles.
I also recommend planning storage not only based on weight but also on access frequency: items that are moved often should be lighter.
taule schrieb:
Thanks, that was exactly the information I was looking for.In addition to proper installation on the right side and observing load limits, reinforcement using angle brackets could be added, especially on the lower compartments.
This improves the load-bearing capacity without significantly altering the appearance.
Another option is to use fewer, thicker wooden shelves instead of multiple thinner ones. These are inherently stronger and allow the shelving unit to hold heavier items more effectively.
Important: The floor must be level to prevent the shelving from leaning and unevenly distributing the loads.
Keatondra12 Sep 2020 09:36Hello, I would like to add that when using KALLAX for storage of heavy loads, securing the shelving unit to the wall is always crucial. Regardless of the weight, wall mounting significantly stabilizes the entire structure.
Additionally, it can be useful to use sturdy storage boxes made of plastic or metal, which help distribute the weight and reduce direct pressure on the shelves.
If you have any questions about how to set up the shelving unit securely, I’m happy to help!
