ᐅ What is the typical load capacity of Billy bookcases?
Created on: 29 Jun 2023 10:37
Noadin
I am currently looking into how much weight IKEA Billy bookcases can typically hold. Specifically, I am interested in how much weight can realistically be placed on each shelf without the bookcase or the shelves permanently warping or getting damaged.
I understand that factors such as the width of the bookcase, the material, and the type of wall mounting also affect the load capacity. However, I would like to hear about your experiences or any technical information you know, ideally including details about the bookcase configuration (e.g., width, number of shelves).
Who uses this bookcase regularly and can provide insights on the maximum or recommended load?
Thanks in advance for your expertise.
kaubi
29 Jun 2023 15:04
Noadin schrieb:
What tips do you or others have to avoid exceeding the load limit? Install more shelves? If so, how many can realistically fit without compromising stability?
Very good question. In general, you can purchase and install additional shelves for Billy, which makes sense especially if you distribute the load across several smaller sections, thereby reducing the weight per shelf.
For a 202 cm (79.5 inch) tall unit, 5 to 6 shelves are typical, particularly since books usually require closer spacing. More shelves do mean more total weight, but it’s better to distribute that weight rather than have fewer shelves carrying a very high load.
Make sure not to exceed the maximum load capacity per shelf and always secure the unit to the wall. If the shelves are mounted with clip supports, ensure they are properly seated, as under heavy load the shelves can lift out if the clips are not firmly in place.
The dimensions of the unit – width and depth – also affect how much a shelf will bend. A 40 cm (16 inch) wide Billy shelf can carry a significantly higher load per shelf than the 80 cm (31.5 inch) wide one, because the boards are shorter and experience less bending stress.
I hope this helps you with your decision.
Charles
30 Jun 2023 09:18
As an additional note: According to an independent test, the load capacity of the Billy shelves is about 15 kg (33 lbs) when the unit is properly secured to the wall. Without wall fixing, this capacity can drop significantly because the shelf becomes more prone to tipping and wobbling.
It should also be noted that the load capacity of older shelves may vary, as the material can lose strength over time or be adversely affected by moisture.
My advice: If you want to store many heavy books, adding metal brackets under the shelf for extra stability is a simple and practical solution.
Jorgela
30 Jun 2023 15:27
I have filled my Billy bookshelf only with books and stick to a maximum of 12 kg (26 lbs) per shelf.
Securing the bookshelf to the wall is mandatory; otherwise, it will be very unstable.
If you have heavy binders, you might want to choose a shelf with metal shelves instead.
TAUFA
1 Jul 2023 08:45
For Billy bookcases, keep in mind: a maximum of about 15 kg (33 lbs) per shelf, preferably less.
Wall mounting is important to avoid the risk of tipping.
More shelves mean better load distribution, which must be taken into account.
Noadin
1 Jul 2023 10:52
Charles schrieb:
If you want to store many heavy books, adding extra metal brackets under the shelf for more stability is a simple, practical solution.
That sounds interesting. Could you or someone else briefly explain how exactly these metal brackets are installed and whether this is supported by IKEA?
Are these DIY solutions or is there original accessory available? Does this affect the appearance of the shelf?
