Hello everyone, I recently bought a Billy bookshelf from IKEA and now I’m wondering how much weight a single shelf can actually hold without sagging or getting damaged. I’m interested both in the maximum load under normal use and in how the weight distribution affects it (e.g., point load versus evenly distributed load). The manual only gives rough estimates and no precise figures about the load capacity of individual shelves, especially for different widths (40cm (16 inches) vs. 80cm (31 inches)). Does anyone have specific experience, measurements, or advice on what to watch out for? Thanks in advance!
I can only agree with kasan; additional reinforcement is often worthwhile for 80cm (31.5 inches) shelves, especially when heavy items like binders are to be stored there. Unfortunately, there are no official specifications for point loads, but due to the material (particleboard), the load-bearing capacity significantly decreases under heavy concentrated loads.
My advice: use shelf inserts or sturdy bookends to distribute the weight more evenly. Regularly checking for sagging also helps prevent damage.
Kinbu schrieb:
My tip: Use shelf liners or sturdy bookends to better distribute the weight.That sounds really helpful! I often forget how important weight distribution is. Sometimes IKEA furniture can feel a bit flimsy, but with tricks like these, you can definitely improve a lot. Thanks!
To add: A single BILLY shelf has a recommended maximum load of about 25 kg (55 lbs) at 40 cm (16 inches) width, and around 15-20 kg (33-44 lbs) at 80 cm (31 inches), as the particleboard with melamine coating is not very resistant to bending. This applies to evenly distributed loads. If heavy items are placed unevenly or at a single point, the bending increases and the shelves may sustain long-term damage. The best practice is therefore to position heavy loads as close as possible to the shelf supports or to add additional supports. Reinforcing with metal brackets can also increase the load capacity.
PULAU schrieb:
The best practice is therefore to position heavy loads as close as possible to the shelving uprights or to install additional supports.I can only agree with that. Even a small central support made of wood or an additional metal beam can significantly reduce bending stress. Anyone planning to use the shelving productively and store heavy items should definitely consider this. The screws and connections of the shelving also matter – they all need to be properly secured to ensure the forces are evenly distributed.
