ᐅ How much space does the IKEA Brimnes wardrobe typically occupy?
Created on: 1 Feb 2024 08:17
Bulelu
Bulelu
1 Feb 2024 08:17
Hello everyone, I am looking for detailed information on how much space the IKEA Brimnes wardrobe typically occupies in a room. I am specifically interested not only in the footprint in terms of width and depth but also the height, as I have spatial constraints and the wardrobe needs to fit against walls with sloped ceilings. It would also be helpful to know if there are different versions that vary significantly in size, as well as any special considerations regarding the dimensions that should be taken into account during planning. Does anyone have experience or reliable information from practice or official sources that they can share here?
Gloriagl10
1 Feb 2024 10:23
The IKEA Brimnes wardrobe comes in several versions, but the standard model measures approximately 120 cm (47 inches) wide, 50 cm (20 inches) deep, and 197 cm (78 inches) high. Some models are wider or narrower, but the height is usually similar. You will need a floor space of about 0.6 square meters (6.5 square feet).
KAULIS
1 Feb 2024 12:41
For reference: The Brimnes wardrobe is commonly sold in two popular versions – a two-door model measuring 120 x 50 x 197 cm (W x D x H) and a three-door model approximately 150 cm (59 inches) wide, with the same depth and height otherwise.
One notable feature is that the wardrobe is not very deep, making it ideal for smaller rooms. However, the height of just under 2 meters (6.5 feet) should be considered to avoid space issues with sloped ceilings.
IKEA specifies a footprint of about 0.6 m² (6.5 sq ft) for the two-door model, while the three-door model requires around 0.75 m² (8 sq ft).
If you need to take sloped ceilings into account, I recommend measuring the exact ceiling height before purchasing, as the top shelf is fixed and cannot be adjusted.
Wesley
2 Feb 2024 09:03
Hey, great question! 😎 I had the Brimnes myself in my guest room and can confirm: the two-door model is nice and slim and easy to assemble. Think of it this way – it holds your odds and ends well without making the room look like a giant’s coat closet. 😉
KAULIS schrieb:
The Brimnes wardrobe is often sold in two popular versions – a two-door model measuring 120 x 50 x 197 cm (W x D x H) and a three-door model that is about 150 cm (59 inches) wide, with the same depth and height otherwise.
That’s exactly how I experienced it too. The height didn’t bother me personally – a sloped ceiling wasn’t an issue for me either. Great space for the price!
SONLIS
2 Feb 2024 14:26
For precise space planning, it is recommended to use the exact external dimensions of the specific Brimnes model.
In general:
- Two-door Brimnes: 120 cm (47 inches) width x 50 cm (20 inches) depth x 197 cm (78 inches) height
- Three-door Brimnes: 150 cm (59 inches) width x 50 cm (20 inches) depth x 197 cm (78 inches) height
The depth is relatively shallow, which makes it suitable for narrower rooms as well. For accurate planning, you should also consider the door opening angle, since the wardrobe doors open outward conventionally and at least 60 cm (24 inches) of clearance in front of the wardrobe should be kept.
In summary, you will need a bit more space than just the physical dimensions to ensure effective use.
