ᐅ How much does 1 square meter of window glass (bay window) cost?
Created on: 29 Sep 2022 21:56
Sonja2Sonja2 schrieb:
How much does one square meter (10.8 square feet) of window glass (flower window) cost?
Approximately how much does it cost to install the glass into the window frame? What exactly is your situation?
When I hear “flower window,” I think of a slightly projecting window, similar to a window seat, but designed to hold flower pots. When these were popular, they were usually fitted with 4mm (0.16 inch) single-pane glass set in wooden frames with putty. The price per square meter for this type of glass is only slightly higher than the cost of the cut piece itself, and the installation is not particularly complicated. It is so straightforward that I don’t quite understand your question. So, do you want to replace the glass? If so, you’d need to check what size fits the frame. Windows from the period when these were fashionable might be due for replacement anyway. Please provide more details about your project.
