ᐅ How many people are needed to assemble large IKEA PAX wardrobes?
Created on: 21 Jun 2023 16:03
U
USNEPE
U
USNEPE
21 Jun 2023 16:03
I am currently planning to assemble a large IKEA PAX wardrobe system in my apartment, consisting of several modular units, each designed to support high loads and offer flexible interior configurations. My specific question is: How many people are ideally needed to assemble such a large-scale PAX wardrobe effectively and safely? I am interested in both the physical strength required—especially for handling heavy components like the wardrobe doors and frame—and the time investment and division of labor during the different assembly steps, from building the carcass to installing the hinges and final securing. Are there any recommendations based on your experience with large PAX modules to help make the process as smooth and damage-free as possible?
gregto
21 Jun 2023 16:47
USNEPE schrieb:
How many people are ideally needed to assemble a large PAX wardrobe effectively and safely?
That’s a very good and precise question, which I would like to answer in detail. Generally, assembling a large IKEA PAX wardrobe is best done with at least two people. There are several reasons for this:
- The individual modules are bulky and often heavy, especially if they are made of wood-based panels.
- When aligning the carcasses on the floor, having assistance helps to ensure accurate assembly.
- For installing the wardrobe doors and hinges, a third hand is often useful, although with some practice, two people can usually manage.
Additionally, I recommend allowing enough time for the assembly, especially if you are building the wardrobe for the first time. A couple of hours per module is normal. It often helps to divide tasks clearly: while one person screws components together, the other holds the carcass or adjusts the door.
If the module is very large or equipped with heavy sliding doors, it can be worthwhile to involve a third person to avoid injuries and damage. Some even recommend four hands for the largest PAX wardrobes.
In summary:
- Two people are sufficient in many cases for standard sizes.
- Three people are ideal for very large versions or tight spaces.
- Experience and safety when handling the components is just as important as the number of helpers.
I hope this already helps to make planning a bit easier!
Davidleo
21 Jun 2023 18:32
gregto schrieb:
Basically, assembling a large IKEA PAX wardrobe is best done with at least two people.
Exactly! From my experience, I can only confirm that two people are absolutely ideal! 😄 Especially when you first see the size of the individual modules, you realize that carrying and holding them alone is often impossible.
I have also assembled it with three people, which is obviously even more relaxed, but usually, two is perfectly fine with proper planning. It’s also important to have all the necessary tools and the instruction manual ready – this saves many unnecessary trips!
And don’t forget: be patient! Sometimes doors are misaligned or the screws don’t cooperate. But that’s all part of the fun! 😊
Conclusion: If you don’t have a third helper, don’t worry, two people usually manage smoothly and you’ll have great success building it!
kaubi
22 Jun 2023 09:14
USNEPE schrieb:
How many people are ideally needed to assemble a large-format PAX wardrobe efficiently and safely?
To answer your question in more detail from a technical perspective, I’ll provide a step-by-step overview of the factors that influence the recommended number of people:
- Weight and dimensions of the modules: Large PAX wardrobes usually consist of several carcasses, which can each weigh over 50 kg (110 lbs), especially when integrated sliding doors are included, which are significantly heavier. Handling these alone is impractical and potentially unsafe.
- Installation environment: Tight spaces often require more planning and coordination. Two people may not be able to work effectively at the same time, so a third person can assist by handing over parts and tools.
- Wall mounting: Securing the modules to the wall and fastening tall and heavy components usually requires firm support. Even if two people hold the carcass, a third person is helpful to pass screws and tools.
- Division of labor during the installation of interior elements: Depending on how many internal drawers, clothing rails, or shelves are installed, an extra pair of hands can reduce assembly time.
- Safety considerations: To avoid injuries from lifting heavy parts or pinching during the securing process, it is advisable not to work alone.
Conclusion: For assembling a complete large PAX system, I recommend at least two well-coordinated people; for more complex modules and confined spaces, three are preferable.
One more tip: Before starting assembly, sort the individual parts and lay out all movable, electrical, or large components separately to avoid mix-ups during the process.
Are there specific room conditions or module sizes you can provide? Then I can offer more precise advice.
