ᐅ How many centimeters do paving stones typically settle after being compacted?
Created on: 22 Jan 2018 19:54
mortensitM
mortensit22 Jan 2018 19:54Hello everyone,
I have an existing raised terrace and would like to add a second, lower terrace. For this, I plan to create a C-shaped strip foundation. On top of that, I want to lay 2-3 rows of natural stone wall blocks (about 28 x 21 x 14 cm (11 x 8 x 6 inches)), bonded with thin-bed mortar. The entire terrace will be only about 30-45 cm (12-18 inches) high and cover an area of around 15 square meters (160 square feet).
The resulting "interior space" will be filled with gravel and compacted, a bedding layer will be applied, and then approximately 8 cm (3 inches) thick paving stones will be installed on top. The border wall and the paving stones should end up at the same height.
My question is whether I need to set the paving stones higher so that after compacting they are level with the wall. If yes, approximately how many centimeters? Or does the paver not settle any further after installation? I have no experience with this.
mortensit23 Jan 2018 09:05I have also been considering this question. Perhaps I should soften the term “natural stone” for this context. I am referring to stones like, for example, the Amalfi series from Koll. It’s certainly not genuine natural stone. The surfaces are also polished smooth. I would compact the gravel fill in layers. The surface does not need to withstand heavy loads. I would have used a small plate compactor. I believe they compact with 20-30 kN.
It is not the paving that is compacted, but its subbase. Specifically, it is compacted evenly to prevent any settling afterward.
