ᐅ How long does it typically take to assemble the Ikea BRIMNES?
Created on: 15 Mar 2024 08:37
Trakeo
Trakeo
15 Mar 2024 08:37
Hello everyone, I am currently planning a new furniture project and considering the Ikea Brimnes. My specific question is: How long does it typically take to assemble this piece of furniture for someone with average experience in furniture assembly? I would like to estimate a realistic timeframe, as I want to account not only for the actual assembly time but also for potential breaks, sorting the parts, and preparing the tools. Are there any experience-based estimates to guide me? Tips on how to make the process more efficient would also be appreciated. Thanks in advance!
Marcellela
15 Mar 2024 09:13
On average, assembling the BRIMNES takes about 1.5 to 2 hours. It is important to read the instructions carefully and sort all the screws beforehand. Having two people is an advantage, as it speeds up the process.
Domau0
15 Mar 2024 12:49
Regarding the average assembly time for the Ikea BRIMNES: My experience shows that it largely depends on prior knowledge, spatial conditions, and the tools available. Specifically:
- Preparation (checking parts, laying out tools): about 20 minutes
- Assembly according to the instructions: approximately 90 minutes, assuming no special prior experience
- Common challenges: fitting the drawers and aligning the hinges require careful work.
- Tip: Mark the parts with small stickers to keep track of the order more easily.
For me, the total time usually settles around 2 hours, slightly more if I focus and avoid mistakes.
It would be interesting to know your circumstances – working alone or with help, which tools you use? Not satisfied with the time? Then we can optimize further.
CHENFAR
15 Mar 2024 15:06
This estimate aligns with commonly reported experiences. Technically, the BRIMNES has a relatively simple design, with a clear parts list and few specialized tools required.
With average DIY skills, it typically takes between 90 and 120 minutes. The time may increase if tools need to be searched for or if there are uncertainties in the instructions.
Recommendation: sort all parts beforehand and read through the entire manual carefully in advance. This saves time and helps prevent mistakes.
Lorukeo
16 Mar 2024 10:22
Domau0 schrieb:
Not happy with the time? Then we can optimize it further.
As a supplement: If you want to optimize the assembly, you should consider the following points:
- Keep tools handy and in good working order; a cordless drill with adjustable torque is ideal
- Follow the instructions step-by-step exactly, especially when installing the drawer slides, as mistakes here can significantly affect functionality
- Use only suitable supports or surfaces for the furniture to avoid damage
- Arrange for an assistant to hold parts or hand you tools
These tips usually reduce the assembly time to the lower end of the typical range, around 60 to 90 minutes.
How was the time calculated in your case?
