ᐅ How long does it typically take to assemble an IKEA Brimnes bed?
Created on: 23 Feb 2019 09:17
japesau
japesau
23 Feb 2019 09:17
Hello everyone, I would like to know how long the average assembly of an IKEA Brimnes bed takes. I am planning to put this bed together soon and want to realistically estimate how much time I should set aside. I am specifically interested in the pure assembly time, excluding unpacking or any delays. Does anyone have experience with the assembly time depending on whether you work alone or with two people? Are there any special tips that speed up or complicate the process? I look forward to your experiences and insights!
sonpar
23 Feb 2019 10:03
Assembly of the Brimnes bed typically takes about 1 to 2 hours. It goes significantly faster with two people, as some parts are relatively heavy. Depending on your DIY experience, it might take a bit less time.
benonon
23 Feb 2019 12:28
I would like to provide a more detailed look at the assembly time of the IKEA Brimnes bed, as the actual time needed depends on several factors. For me, the entire assembly—including unpacking the parts and sorting them—took about 2 hours. With a second person helping, this can be reduced to just under one hour, especially if both coordinate well and have the necessary tools like screwdrivers or a cordless drill ready at hand.
Here is a rough breakdown:
- Unpacking and sorting parts: 15–20 minutes
- Assembling the bed frame(s): 30–40 minutes
- Installing the slatted frame and connecting elements: 20–30 minutes
- Final tightening of screws and inspection: 10–15 minutes
It is important to read the assembly instructions carefully and pre-sort the included screws by type and size. Impatience can quickly lead to mistakes and delays. Also, assembly time may vary depending on the set (with or without drawers). Does anyone use special tools that speed up the assembly? That can sometimes make a difference.
pikin
24 Feb 2019 08:44
benonon schrieb:
For me, assembly alone, including unpacking the parts and sorting them, took about 2 hours.
This matches my experience as well. In my opinion, the assembly time largely depends on the preparation. A structured approach, meaning sorting screws and parts beforehand, reduces the risk of time-consuming searches.
Additionally, the duration varies depending on prior experience. Those who regularly assemble furniture often complete the task faster than beginners. I also recommend involving a second person, as handling the side panels with two people is much easier and quicker. This not only speeds up the process but also helps prevent possible damage and mistakes.
Ultimately, an average assembly time of 1.5 to 2 hours can be expected when considering all factors.
Foster63
24 Feb 2019 16:19
japesau schrieb:
I am planning to assemble this bed soon and would like to realistically estimate how much time I need to set aside.
A realistic estimate is indeed important to avoid stress. If you want to be cautious, it’s better to allocate 2 hours to give yourself enough time. It is advisable to take regular breaks during assembly and follow the instructions step by step. If you’re assembling alone, 1.5 to 2 hours is a good guideline. As mentioned before, having a second person helps a lot, especially with heavy or awkward parts.
If you have never assembled IKEA furniture before, you might need a bit more time until you get the hang of it. Also, tools like a cordless drill can make the assembly much easier.
