ᐅ How long does it take to assemble an IKEA BRIMNES wardrobe?
Created on: 27 Jan 2016 08:23
Kau33
Kau33
27 Jan 2016 08:23
I am planning to buy the IKEA Brimnes wardrobe but am unsure how much time I should allocate for assembly. My specific question is: How long does it usually take to assemble an IKEA BRIMNES wardrobe on average when using the included instructions and having at least some experience with furniture assembly?
It would be great if you could also share whether the assembly times vary significantly depending on the model version or the number of doors. I appreciate any tips!
Joshbe
27 Jan 2016 09:16
Kau33 schrieb:
How long does it usually take to assemble an IKEA BRIMNES wardrobe on average, using the included instructions and with at least some experience in furniture assembly?
The average assembly time for a BRIMNES wardrobe generally ranges between 75 and 120 minutes, depending on experience and the number of people involved.
Important considerations:
- BRIMNES is available in different versions (e.g., 2-door, 3-door, sliding doors), which can affect assembly time.
- The instructions are clearly structured, but identifying the individual parts can take some extra time.
A single person with some experience should allow about 1.5 hours. Two people can significantly speed up the process.
parpeo
27 Jan 2016 10:02
Joshbe schrieb:
The average assembly time for a BRIMNES wardrobe typically ranges between 75 and 120 minutes, depending on the experience and number of people involved.
That’s correct. Additionally, I would like to emphasize the importance of taking some time before starting to check all parts and prepare the necessary tools.
For someone assembling a BRIMNES wardrobe for the first time, I would recommend allocating around 2 hours to avoid feeling rushed. Patience is especially important when carefully fitting the sliding doors or drawers.
leebi7
27 Jan 2016 11:57
To thoroughly address the assembly time of an IKEA BRIMNES wardrobe, I would like to add some technical details and explain the assembly process.
First:
- The model with sliding doors generally takes more time because the door mechanism needs precise adjustment.
- There are parts that look similar, such as shelves and side panels, so it is important to follow the numbering carefully.
Step-by-step:
1. Check all parts and fittings: Organizing enables a faster start.
2. Assemble the frame: Usually takes 40-60 minutes, depending on experience.
3. Install the doors/sliding doors: More technically challenging, 30-40 minutes.
4. Fit the drawers (if included): 15-20 minutes.
Do you have a specific model variant (e.g., number of doors, dimensions) or are you planning to assemble the wardrobe alone? This will influence the time estimate.
Kau33
28 Jan 2016 07:44
leebi7 schrieb:
Do you have a specific model version (e.g., number of doors, dimensions) or are you planning to assemble the wardrobe on your own?
Thank you for the detailed overview. It is the version with two doors, no sliding doors, and I will be assembling it on my own.
Do you have any practical tips to optimize the time or avoid common pitfalls? Also, I sometimes find it difficult to identify the screws; how do you handle this during your assembly?
Enrico4
28 Jan 2016 09:30
Kau33 schrieb:
Do you have any practical tips to optimize time or avoid pitfalls?
One thing upfront: saving time also means being prepared.
- Immediately sort all screws and fasteners by size and type.
- Place the fittings next to their corresponding components.
- Use a cordless screwdriver with adjustable torque to speed up assembly without damaging materials.
- Follow the instructions step by step.
- A calm and focused approach helps prevent mistakes that could cost time later.
For the version with two doors, make sure to carefully secure the door hinges to ensure precise closing later.
