ᐅ How long does it actually take to assemble the Ikea Hemnes?
Created on: 7 Nov 2021 08:42
jugau41
jugau41
7 Nov 2021 08:42
Hello everyone, I recently ordered a Hemnes bed from Ikea and now I’m wondering: How long does it really take to assemble the Ikea Hemnes? I’ve seen different answers in various forums – from 1 hour up to 4 hours with 2 people. It would be very helpful for me if you could share your actual experiences regarding the assembly time. I’m especially interested in how time-consuming the assembly is, including the drawers, if you have some DIY skills but are not a professional. Are there any common pitfalls that tend to make the process take longer? Thanks in advance for your input!
BARSAN
7 Nov 2021 09:23
I assembled the Hemnes bed with drawers last year. With two people, it takes about 2 hours if you work in a reasonably organized way. Important: Do not overtighten the screws and sort all parts before starting.
taudi
7 Nov 2021 10:07
Regarding the assembly time for the Hemnes bed: I recommend the following procedure to speed up the process and avoid mistakes:
- Carefully open the packaging and check all parts for completeness.
- Sort the components according to the instructions and match them with the labels.
- Initially, tighten screws only lightly; fully tighten them at the end to prevent alignment issues.
With this approach, two people can usually finish in about 2 to 3 hours. The drawers are often the most time-consuming part because the rails need to be precisely aligned. Patience is an important factor here.
Henry
7 Nov 2021 11:12
I can understand well that the assembly time, especially for beds with drawers, can be somewhat uncertain. I was uncertain myself at the beginning when I assembled my Hemnes. For me, it took about 3 hours in total, as I needed to pause from time to time to think about whether I was doing everything correctly – this is something many beginners experience. Keep your spirits up; it is completely normal to pause occasionally. Especially if you are assembling alone, it can understandably take longer.
Guyju
7 Nov 2021 12:39
Regarding assembly time, here is a detailed estimate:
1. Preparation: 10-15 minutes
2. Assembling side panels and head/footboard: 40-60 minutes
3. Installing the slatted frame: 15-20 minutes
4. Drawer assembly: 45-60 minutes (due to precise rail adjustment)
Overall, with two people, I recommend planning about 2.5 to 3 hours. If you are working alone, it can easily take an hour or more longer. My advice: work step by step and take your time with the drawers, as they are definitely the most critical part. A screwdriver with a comfortable grip makes the assembly much easier.
jugau41
7 Nov 2021 13:01
Guyju schrieb:
If you don’t have any help, it can easily take an hour or more extra.
That’s interesting, I had actually considered assembling the bed on my own. Based on your experience, are there any negative effects on quality or safety when one person does it alone? Would it just be more complicated, or is it mainly the time required that increases?
