ᐅ How long does an Ikea Metod kitchen typically last with regular use?
Created on: 11 Jul 2020 08:37
praklaus
Good morning everyone, I am currently planning to purchase an Ikea Metod kitchen and am looking into how durable it is with regular use. Specifically, I am interested in how many years one can generally expect the individual components – cabinets, fronts, fittings, and hinges – to last with daily, normal use. Are there any experiences or estimates on how long such a kitchen typically lasts before major repairs or even a replacement might be necessary? Thank you in advance for your insights.
Regarding the moisture resistance of the Ikea Metod kitchen: - The cabinets are not waterproof; moisture at the edges causes swelling. - Therefore, it is important to avoid standing water and to wipe off splashes immediately. - Care tips: wipe fronts with a mild cleaner, avoid strong chemicals. - Check rubber or silicone seals on sink base cabinets regularly to prevent water damage. - Those living in very humid environments should consider additional elements like water-resistant fronts (also available from Ikea). This helps maintain durability even under moisture exposure.
praklaus schrieb:
How does it hold up in terms of stability with moisture? My kitchen isn’t completely dry—more like a typical household with occasional splashes and steam exposure. Here is a straightforward assessment: With normal kitchen moisture, a Metod kitchen will easily last 10–15 years. The coating offers some protection. Prolonged exposure to water, such as from leaking water connections or poorly sealed sink cabinets, will cause damage sooner. Therefore, properly installed and well-sealed components are essential.
A tip regarding durability: Pay attention during installation and use to - proper assembly of the corner joints to ensure stability - use of original fittings, as issues may arise otherwise - regular inspection of hinges and guide rails as well as their lubrication. I have had my Metod kitchen for 10 years and have replaced some parts myself, which worked smoothly with original components. Summary: the kitchen is durable if essential maintenance is carried out.
Cecilera6614 Jul 2020 15:13In summary: The Ikea Metod kitchen lasts around 10-15 years with regular, normal use. Smaller wear parts such as hinges, drawers, or damping systems should be checked after about 5-10 years and replaced if necessary. Proper installation and maintenance to protect against moisture damage are important. Especially with an investment like this, I would consider the lifespan only as a guideline, since individual use and assembly play a major role.
