ᐅ How large is your rainwater cistern?
Created on: 2 Apr 2016 11:13
housedreamer
housedreamer2 Apr 2016 11:13
We have a 450 sqm (4,844 sq ft) plot and want to install a cistern. Is 7 cubic meters enough, or is it better to plan for 10 cubic meters?
How large are your cisterns?
housedreamer
Legurit
2 Apr 2016 11:23
Maybe I’ll expose myself again as an uninformed layperson, but isn’t it about the sealed surface area or the roof area that needs to be drained?
Irgendwoabaier
2 Apr 2016 11:47
Oh, it’s simply about how much water comes in (rainfall on the area to be drained) and how much water goes out (garden irrigation / domestic water system / snow cannon, etc.). One shouldn’t forget that the overflow of the cistern should occasionally activate; otherwise, too much debris accumulates inside the cistern.
We have 4.5 cubic meters (160 cubic feet) – that’s enough for our garden irrigation only. But of course, it depends on how much you need to water and how intensively you do it...
Uwe822 Apr 2016 15:16
Do you want to or do you have to? If you don’t have to, then calculate carefully—it usually isn’t worth it.
One003 Apr 2016 10:46
We have slightly over 10 sqm (107 sq ft) total volume and 5 sqm (54 sq ft) retention volume.
That was the regulation in our area.
I have already heard everything about this, from "way too large" to "it can never be too big," although I wouldn’t support the latter because of the previously mentioned overflow.
It depends on the factors mentioned in earlier posts (sealed surfaces, usage behavior, etc.).
Polle 1967
3 Apr 2016 13:38
Hello, what does the development plan say?
For us, 5 cubic meters was mandatory, but we built 6.5. The cost for the additional 1.5 cubic meters was minimal.
What do you want to use the cistern for?
