ᐅ How is the typical wood grain pattern created in IKEA Hemnes furniture?
Created on: 5 Feb 2024 09:18
Saumi
Saumi
5 Feb 2024 09:18
Hello everyone, I am currently looking into how the characteristic wood grain develops, especially in IKEA Hemnes furniture. I am particularly interested in how this grain is created—whether it results from the natural raw material, the manufacturing process, or a specific surface treatment. Is the grain in Hemnes mainly due to selecting wood pieces with pronounced texture, or is it enhanced through techniques such as veneer application, wood staining, or other methods? Additionally, I would like to know which type of wood is typically used for Hemnes and how the choice of wood influences the visual effect of the grain. Are there any differences compared to the grain patterns in other IKEA product lines? It would be great if someone could explain the production steps and materials from a technical perspective, as I have heard varying information and would appreciate a well-founded overview.
bapar
5 Feb 2024 11:47
Hello Saumi, your question is very well formulated, as the grain pattern in Hemnes actually combines several factors. Basically, the typical style is based on pine wood, which is almost always used in Hemnes. Pine is a softer type of wood with a very pronounced, natural grain pattern. The grain is created by the growth rings and the wood fiber structure visible in cross-section. It is important to know that IKEA sorts and treats the wood in a standardized way to achieve a certain consistency, but at the same time, the natural structure is consciously preserved.
- Hemnes mostly uses solid pine wood, not veneer, so the grain is genuine and not artificially created.
- The wood is dried before processing to avoid warping, which also keeps the visible structure stable.
- After cutting, a surface treatment is applied with lacquered or waxed sealing that enhances the visibility of the grain and protects it.
An important point is the surface treatment: The finish used highlights the natural grain by emphasizing the wood pores without completely covering them. This results in the warm, slightly rustic look typical of Hemnes.
Compared to other IKEA ranges that often use veneer or partly pressed chipboard (such as the Malm series), the solid pine wood in Hemnes makes the grain a bit more individual and lively.
I would be interested to know which type of furniture or specific Hemnes piece you are referring to? The grain can vary slightly depending on the batch and the particular cut of the wood used.
Dustin
5 Feb 2024 15:03
In short: The typical grain pattern in Hemnes furniture occurs because solid pine wood is used. The grain comes from the natural wood structure. The surface is then treated with a clear finish or a thin varnish to highlight the texture without covering it up.
Blavin
6 Feb 2024 08:09
Saumi,
in addition to what has already been mentioned, I would like to highlight some technical details that significantly contribute to the grain appearance of IKEA Hemnes:
- The pine wood is FSC-certified, sustainable forest wood, which implies a certain quality assurance regarding the wood’s quality.
- Since the furniture is made from solid wood, the wood is individually selected and sorted, so each piece has a unique grain pattern.
- During processing, Hemnes often uses sanding techniques with fine grits to achieve a smooth surface that also highlights the grain very well.
- The final treatment is usually done with thin-layer varnishes or waxes, which not only repel dirt but also emphasize the wood’s pore structure. This results in a depth effect of the grain that you don’t see with cheaper furniture made from particleboard.
- Some Hemnes variants also feature light staining to tone down the natural yellowish color of the pine wood and create a more uniform shade.
Therefore, the grain is primarily naturally caused but is deliberately enhanced through careful sorting and surface treatment. This creates the distinctive appearance.
anken
7 Feb 2024 13:57
Saumi schrieb:
I am particularly interested in how exactly this grain pattern is formed and whether it results from the natural raw material, the manufacturing process, or a specific surface treatment.
That is exactly the point: the grain pattern in Hemnes comes from the natural structure of the pine wood, which is the base material.
In addition, the careful selection of the wood shapes the final product. Pine grows with clearly visible annual rings and grain lines, which are responsible for the pattern.
It is also important to know that IKEA uses solid wood for Hemnes – no veneers. This means the grain is authentic and varies from piece to piece.
The manufacturing process includes drying the wood, which reduces warping and improves surface quality. Fine sanding then prepares the wood for sealing. This sealing is usually transparent and enhances the natural grain without creating artificial patterns.
All in all, the combination of natural material and gentle surface treatment gives the grain in Hemnes its distinctive and high-quality appearance.
