Hello everyone, I recently purchased the Metod kitchen system from Ikea and am now facing the challenge of properly assembling the sink cabinet. My specific question is: How do I assemble the Metod sink cabinet so that it stands stable, the cutout for the sink fits correctly, and there is still enough space for the plumbing and the trap? Maybe you can give me tips on the best way to approach the assembly, which screws are essential to use, and what to pay special attention to when joining the cabinet sides? I am also interested in whether it’s better to attach the bottom rail before or after assembly and how to properly adjust the door hinges so that they don’t sag. Thanks in advance for your help!
It is best to install the adjustable feet after assembling the main structure and once it is in its final position. This allows you to adjust the height optimally and compensate for any unevenness. For uneven floors, it helps to set the feet securely, ideally checking with a spirit level. Do not screw the base rail on too tightly, in case you need to make small adjustments later.
JEREMIAH381 Apr 2023 17:23drage0 schrieb:
My kitchen isn’t perfectly level, and I’ve heard that adjustable feet can help compensate for unevenness – but I’m unsure whether they make installation easier or more difficult.I know exactly what you mean, I had the same experience! I only attached my adjustable feet after fully assembling the cabinet because it’s definitely easier to build the cabinet “dry” first and then adjust it to the correct height. This way, you can fine-tune without putting unnecessary stress on the cabinet frame. For slightly uneven tiles, I made sure all feet had firm contact – this provides a more stable base.
draFrederi2 Apr 2023 08:41Additionally: When adjusting the doors, take your time and ideally work on one door at a time. The Metod hinges allow for perfect alignment thanks to their adjustment options. Pay close attention to the gap between the door and the bottom track, otherwise the door may scrape when opening. If you position the cabinet close to the floor, it is advisable to use rubber bumpers or door edge protectors to prevent damage.
draFrederi schrieb:
The Metod hinges allow you to achieve a perfect alignment thanks to their adjustment options.That is absolutely correct. I would also add that when installing the doors, you should focus on aligning them with the surrounding furniture or countertop, even when the doors are already mounted. This is especially important for sink cabinets, where the door must not hit the countertop when opened. When in doubt, it’s better to leave a bit of clearance and then fine-tune the fit using the hinges.
Thank you very much for the very helpful and detailed advice from everyone! I now feel much better prepared, especially regarding the installation of the bottom rail and leveling feet, as well as door adjustment. During assembly, I will pay close attention to the Minimifix connections and take plenty of time for the hinges. Should I use any special tools for a more precise adjustment of the Metod hinges, or are regular screwdrivers sufficient? If anyone has tips, I would really appreciate it!
