Hello everyone, I recently bought a Brimnes bed from IKEA, and I’m having some trouble with the assembly of the back panel. My question is: How exactly is the IKEA BRIMNES back panel attached? Are there specific screws or fastening points that need to be considered? I have looked at the instructions several times, but the description for attaching the back panel is a bit brief and unclear to me. I would greatly appreciate detailed tips, such as the sequence of steps, handling during fastening, or possible challenges when fitting it.
I’m familiar with the issue of getting panels to sit flush! Tip: First, position the back panel loosely against the side panels and carefully insert one screw on each side without fully tightening them. This way, you can still adjust and reposition the back panel. Only once everything fits perfectly, tighten the screws fully. A bit of patience helps – it works like a puzzle. And don’t worry, you won’t damage the back panel if you handle it gently.
Ramoritz schrieb:
I guess I need to position them correctly first That’s exactly the key point, but I wonder: Was the back panel of your model possibly delivered without the correct pre-drilled holes? There was a batch where some back panels were either shifted or the holes didn’t line up properly. I would double-check if all the holes really match the side panels; otherwise, it could be a manufacturing defect.
daalessio18 Jan 2022 11:30In addition to the previous posts, here is a tip regarding the choice of tools: Ikea often recommends using a Phillips screwdriver for assembly, but a cordless drill with adjustable torque makes fastening much easier and more secure. Be careful not to set the torque too high, especially when working with thin panels such as the back panel. This helps prevent tearing out and damage. It is also helpful to start the screws at an angle to guide them more easily before driving them in straight.
BAUEVA schrieb:
I would double-check if all the holes really align with the side panels Thank you, that’s a good point. I actually had the impression that one side of the back panel might have a slight offset issue. I will measure and inspect it carefully again. If it really is a defect, it’s definitely worth considering an exchange. Are there any other tips on how to check for manufacturing deviations in furniture before assembling everything completely?
Ramoritz schrieb:
Are there any other tips on how to check for manufacturing deviations in furniture before fully assembling everything? Very good question! The best way is to unpack all the individual parts completely and lay them out side by side. Visually check for:
- Irregularities along the edges
- Drill holes: Are the spacing and positions matching on both sides?
- Surface: Are there any dents or deformations?
If you notice any deviations, take measurements using a tape measure or ruler. Compare identical parts with each other. If the back panel or side parts are not symmetrical, you may face problems with parts not fitting flush. This occasionally happens, especially with lower-cost furniture.
If you don’t see any issues, assemble the frame loosely at first, securing it with just a few screws, to test the fit before fully tightening everything.
Sometimes it also helps to file down the back panel a bit if it fits too tightly. Usually, it’s just small edges catching on something. But only do this if you are sure it’s not a product defect. Work carefully, the boards are thin! Check the screw holes again before drilling; sometimes the pre-drilled holes aren’t deep enough.
