ᐅ What is the most secure way to assemble Ikea Hemnes shelves?
Created on: 28 May 2019 08:32
Jan-jorik
Jan-jorik
28 May 2019 08:32
Hello everyone, I am currently planning to install an Ikea Hemnes shelving unit and want to secure it to the wall as firmly as possible. My question is: What is the most stable way to mount Ikea Hemnes shelves? I have reviewed the instructions, but the recommendations there are not detailed enough for my wall types (partly drywall, partly concrete). What additional measures or tools would you suggest to ensure the shelf remains safe and stable over the long term, with no risk of tipping over or loose connections? I would appreciate advice on suitable anchors, screws, wall attachments, and how to connect the shelf components securely. Thank you!
V
vinli
28 May 2019 09:17
For the most secure installation of an Ikea Hemnes shelf, I recommend the following steps:
- Use washers with the screws to prevent damage to the wood and to provide a larger bearing surface.
- For drywall, always use special drywall anchors (e.g., toggle bolts, cavity anchors) that provide sufficient load capacity.
- For concrete walls, nylon or metal anchors suitable for the wall thickness are advisable.
- Always use the supplied wall brackets, as they prevent tipping.
- For larger shelves, consider mounting additional angle brackets to better distribute the load on the wall.
- When assembling the shelf components, ensure all connections are tight to avoid any movement or vibrations.
This combination ensures long-lasting stability.
susar
28 May 2019 11:54
Hey Jan-jorik, good luck with your project! 🙂 I mounted my Hemnes shelf myself on a drywall and can only recommend using good anchors. I always use these special hollow wall anchors, which hold really securely! The installation can be a bit tricky, but it’s definitely worth it. Once the shelf is up, it looks great and is very stable. 😊 Also, remember to check the shelf regularly, especially if you put heavy items on it. You’ve got this!
taudi
28 May 2019 14:23
For a detailed explanation of the most secure way to install Ikea Hemnes shelves, here are some tips in the form of a short tutorial:
1. Preparation:
- Use a stud finder to locate studs in walls or the ceiling, if available.
- The shelf can be directly screwed into these studs, providing much better support.
2. Choice of fasteners:
- For drywall: use hollow wall anchors or metal anchors, never simple plastic anchors.
- For concrete: use nylon or metal anchors of the appropriate length.
3. Caution during assembly:
- Fully assemble the shelf components before tightening screws, so you can check the joints.
- Pre-drill holes in the shelf parts, especially in the wooden components that will hold the wall brackets.
4. Wall mounting:
- Always use wall brackets and secure them with multiple screws and anchors if possible.
- For extra stability, slim metal brackets can also be mounted on the back.
5. Securing against tipping:
- Hemnes shelves are relatively tall; therefore, secure them against tipping, for example with L-shaped wall anchors.
6. Load distribution:
- Place heavy items on lower shelves to reduce the risk of tipping.
By following these steps, the installation will be stable, safe, and durable.
PIERCE
28 May 2019 17:06
Always install the Hemnes shelf using the included wall brackets and use anchors suitable for your wall type. Drywall requires hollow wall anchors, while concrete requires hammer-in anchors. Tighten all connections securely.
mifra
29 May 2019 08:42
taudi schrieb:
For additional stability, narrow metal brackets can also be installed on the back.
I can only confirm that. Especially with Hemnes shelves, the extra installation of metal brackets may appear inconspicuous but clearly provides much greater rigidity. It is also important not to leave any of the supplied screws too loose, even if the wood doesn’t feel perfectly flush the first time. Retightening the screws after a few weeks is advisable to ensure long-term stability.
