ᐅ How good is the quality of the IKEA BRIMNES hinges?
Created on: 20 Sep 2022 08:23
Loluan
Loluan
20 Sep 2022 08:23
Hello everyone, I am currently planning a furniture assembly using the IKEA Brimnes hinges and would like to get a clearer idea of their quality before purchasing. Specifically, I am interested in how durable and stable the hinges are in everyday use, whether they are easy to adjust, and if there are any known weak points. I have already read that some IKEA fittings can have issues with frequent use or heavy loads. Does anyone have practical experience with the BRIMNES hinges, especially regarding material quality, workmanship, and longevity? I would also like to know if alternative fittings are worth considering or if the BRIMNES hinges are truly solid for the price.
Takutau
20 Sep 2022 09:11
Hello Loluan, regarding your questions: The IKEA BRIMNES hinges are actually designed for typical residential use and provide satisfactory stability. It is important that they are installed correctly; otherwise, frequent use may lead to early wear.
- They are easy to adjust, usually well managed with the two adjustment screws.
- The material quality is average; for very heavy or heavily used doors, an upgrade is often recommended.
- Weak points usually appear in the plastic components, which can become a bit loose over time.
If you require high load capacity, you should consider alternatives made of metal or branded fittings. For standard applications, however, BRIMNES offers good value for money.
GiRoyce
20 Sep 2022 10:45
I installed BRIMNES hinges at my home, specifically on my wardrobes. So far, I haven’t had any problems with them; they operate smoothly and don’t wobble. In my experience, it’s important not to handle them too roughly and to follow the installation instructions carefully.
If you open and close the hinges several times a day, the material may show slight wear after a few years, but until now they have not caused any failures.
JAMESONB41
20 Sep 2022 11:02
The BRIMNES hinges are designed for light to medium use. For kitchens, different hinges should be used. Stability and adjustment are adequate but not a high-end solution.
sinhau
20 Sep 2022 13:38
Hello Loluan, I am happy to provide you with a more detailed assessment of the BRIMNES hinges.
1. Installation: These hinges are standard single-hole hinges and require precise marking and secure screwing. Attention should be paid to the drilling depth to avoid material splitting.
2. Adjustment: They offer two adjustment options, horizontal and vertical, which work well for fine tuning. However, the adjustment range is limited, which can be problematic for severely warped doors.
3. Material: The hinges are mainly made of steel and metal alloys, with plastic components mainly in the cover clip and fastening parts. These plastic parts can become brittle over time with heavy use.
4. Durability: They are suitable for normal residential use. Heavy use or high moisture exposure can be problematic. The hinges typically show wear after about 3–5 years, but usually not prematurely.
Summary: For standard furniture, the IKEA BRIMNES hinges are solid if installed correctly. Those who expect more or have special requirements should consider alternatives.
karlau
21 Sep 2022 07:15
I often wonder whether it’s truly worth trusting IKEA for quality or if they’re cutting corners in the wrong areas.
Takutau schrieb:
For standard applications, BRIMNES offers good value for money.
I would disagree with that. Value aside, hinges are wear parts, and with IKEA you get less durable components for a low price. If you’re thinking long-term, it’s better to opt for branded fittings.
Of course, this is sufficient for ordinary wardrobes or bedroom cabinets, but honestly: hinges are crucial for doors – and that’s not something to compromise on.
