Hello everyone, I have a question regarding the mechanical durability of the screw connections in Ikea Platsa furniture. Specifically, I’m interested in how durable these connections are over longer periods when they are subjected to regular use. Since Ikea often offers furniture for flexible living situations, I wonder how well the screw connections – mostly metal-to-particleboard joints with dowels and metal brackets – hold up in everyday use, especially when the furniture is frequently taken apart and reassembled or slightly rearranged. Are the screw holes fairly resistant to wear, or is there a risk that repeated screwing causes the material to degrade and the connection to become unstable? Has anyone had experience regarding the long-term durability, particularly concerning weight load, repeated assembling and disassembling, and tightly fastened screws? Thanks for any insights!
Kaleo schrieb:
how durable these connections are over longer periods when they are regularly loaded.Honestly, I’ve been using a PLATSA structure for 3 years now, and apart from a slight creaking noise, everything held up well. Of course, carrying it around or assembling and disassembling it multiple times does have an effect, making it a bit wobbly at times—but nothing that can’t be fixed with a drop of threadlocker or by tightening the screws again. So I’d say: good durability for the price! 😉
Regarding material wear—the holes in PLATSA are a bit softer compared to more expensive furniture, so the threads can wear out if you frequently screw and unscrew. But who really minds at that price? Just be a little careful when screwing, and it’ll be fine.
To answer the question about the durability of the screw connection in Ikea PLATSA furniture in more detail, I would like to explain some technical aspects and common weak points.
PLATSA furniture is mainly made of particleboard with a melamine coating, which, combined with the screws and dowels used, provides reasonable stability. The typical screws are usually wood screws or so-called Confirmat screws, which are designed for furniture where the connection is made into particleboard or MDF panels.
- The durability of the screw connection largely depends on whether you frequently disassemble and reassemble the furniture. Repeated screwing and unscrewing causes mechanical stress on the fiber material, and the screw holes can become worn over time, especially if screws are driven in too deeply or handled carelessly during repeated assembly.
- It is recommended to use metal or plastic sleeves (e.g., screw anchors) when assembling multiple times to stabilize the hole.
- Loads from weight mainly affect the connection points. In PLATSA furniture, heavy loads and swivel movements can cause the screw joints to loosen.
- For long-term stability, I advise tightening the screws as needed but being careful not to damage the particleboard.
- Minor repairs such as filling worn-out holes with wood filler or special putty can significantly extend the lifespan.
I would be interested to know if you plan to keep the furniture in one place permanently or if frequent moves and reassemblies are expected. This can influence the maintenance strategy for the connections.
raulso schrieb:
the holes in PLATSA are somewhat softer than in more expensive furnitureThat’s exactly the point nobody really wants to admit: PLATSA is designed for quick, inexpensive furnishing, not for long-term, heavy use. I mean, how can durability be expected when drilling into 12mm (0.47 inches) particleboard? Unlike solid wood furniture or genuine custom cabinetry, the screw connections here are more like toys than a long-lasting construction.
I argue that anyone expecting PLATSA to behave like a solid wood cabinet with real screw joints will be disappointed. Sure, it lasts a few years, but even with careful use, the material is simply too weak. And even more weaknesses develop with frequent assembly and disassembly, so it’s completely normal for the connections to loosen quickly.
At best, you can try external solutions like glue or extra fasteners – everything else is wishful thinking. The real question is: Are you aiming for durability, or do you accept that this system is designed for low cost and flexibility?
Z
zarJody683 Sep 2022 10:02I would like to add to the discussion with a clear, fact-based assessment:
PLATSA uses standardized particle boards with a melamine coating, connected by metal brackets, wooden dowels, and screw-in dowels. The screw connections themselves are designed to last several years with proper use, provided that:
- The screws are tightened with the correct torque,
- There is no over-tightening or unnecessary re-tightening,
- The furniture is not subjected to regular assembly and disassembly cycles.
From a technical perspective, the durability is limited by the strength of the base board material, which fatigues after multiple assembly processes. To reinforce the connection, plastic or metal sleeves could be inserted into the screw holes, although this is rarely the case with Ikea products.
In summary: for normal household use with minimal disassembly, the screw connection is functionally durable. For frequent relocations or repeated reassembly, it is less suitable.
If frequent disassembly and reassembly are planned, I recommend considering additional reinforcements or alternative connection methods.
