ᐅ How durable are Malm furniture pieces after years of continuous use?
Created on: 3 Feb 2021 18:23
neobi39
neobi39
3 Feb 2021 18:23
I am currently looking into how sturdy Malm furniture (especially drawer chests and sideboards) actually is after several years of continuous use. The question is not only about visible wear but primarily about structural stability: Do the furniture pieces warp, do drawer runners break, or does material fatigue occur? I would especially like to hear from people who have been regularly using and loading their Malm furniture for at least five years. How well do the connectors hold up? Are adjustments or even repairs necessary after a few years? And how does the material perform regarding abrasion, moisture, or weight? It would be great if you could share your experiences, including the exact length of use and any maintenance or modifications made.
Seanni
3 Feb 2021 20:11
Hello neobi39,
I’ve had a Malm dresser in my bedroom for about 6 years now and can say that these pieces are really sturdy for everyday use. Of course, you can tell they’re not made of solid wood and are generally less hefty than some expensive furniture. But my drawers still slide quite smoothly and nothing sticks. The edges of the drawer fronts show slight signs of wear, which is to be expected.
neobi39 schrieb:
how stable Malm furniture actually is after several years of constant use
I think if you use the furniture moderately, it remains fairly stable over the long term. But if you constantly stuff heavy items into the drawers, you might run into limits after a few years. I haven’t stored anything heavy in the dresser, so everything has worked fine :-) Overall, I’d say it offers good value for the price if you don’t expect too much.
Tevin
4 Feb 2021 08:47
Good morning everyone,
I’m happy to add to the question, as I have been using a Malm desk and a Malm chest of drawers for about 7 years. It is important to understand that Malm furniture is made from particleboard covered with melamine foil. This material has both advantages and disadvantages.
neobi39 schrieb:
Do the furniture warp, do drawer slides break, or does material fatigue occur?
Typical weak points are indeed the drawer slides, especially under heavy use – these are usually made of plastic. After several years, it is not uncommon for fittings to loosen or wear out, requiring adjustments. Moisture can also cause the particleboard to swell, so Malm furniture is not ideal for damp rooms. Regular care, such as dusting and avoiding excessive weight, extends the furniture’s lifespan.
If you keep this in mind, they remain stable and offer a lot of storage space at a comparatively low price.
In summary: check the fastenings, avoid heavy loads, and keep the furniture dry, and Malm furniture will still look good after several years.
RENMA
4 Feb 2021 12:36
I would like to add to the discussion from a technical perspective.
Material:
Malm furniture is primarily made of particleboard with a melamine resin coating. This material is cost-effective and scratch-resistant but not completely moisture-proof, which can cause swelling.
Long-term stability:
- Fasteners: Usually metal dowels and screws that can loosen over time with continuous use. Tightening by the user may be necessary.
- Drawer slides: Plastic or metal guides; plastic guides often show wear after several years of use and may need to be replaced.
- Load capacity: The manufacturer’s specified maximum load is usually around 15–25 kg (33–55 lbs) per drawer, but this can vary in practice if excessively heavy items are stored long-term.
Recommendation:
Regularly check the mechanical connections and perform maintenance or replace fittings promptly at the first signs of weakness. Avoid exposure to moisture.
Following these recommendations generally results in satisfactory stability for regular use.
REPITAR
5 Feb 2021 14:02
I would like to share some practical tips for the care and maintenance of Malm furniture that can significantly extend its lifespan.
1. Regularly tighten screws: Especially after assembly and again after about one year, connections can loosen.
2. Gentle cleaning: Avoid abrasive cleaners to protect the melamine surface.
3. Distribute weight evenly: Place heavy items evenly in the drawers and avoid constant loading in one spot.
4. Lubricate or clean drawer runners: Although plastic runners often require little maintenance, dust and dirt can affect their smooth operation.
5. Protect from moisture: Avoid placing the furniture in damp rooms or exposing it to water.
RENMA schrieb:
Connection elements that can loosen over time under constant use
I can confirm that. After three years, I tightened all the screws, and since then everything has been much more stable.
In conclusion: The furniture is not premium quality, but for the price, it’s a good piece if you give it a little attention.
Layla
5 Feb 2021 19:29
I like how the responses here are both factual and helpful! I’ve been using my Malm chest of drawers for about 5 years now – to be honest, sometimes I worry because I move it around quite often and have shifted rather heavy stuff from one place to another.
Seanni schrieb:
For everyday use, these things are really sturdy
I agree with that, but for me, everyday use isn’t always exactly “normal” ;-)
You can tell that many parts of the Malm lack durability when overloaded. But it’s reassuring to know others experience the same and that often small repairs or adjustments can fix a lot. Thanks for that!
I followed the advice to tighten the screws – that really helped me, the piece feels much more stable now, even though I still have some anxiety that something might break. Maybe you just have to accept that this furniture isn’t an investment piece for life, but still solid enough for 5–7 years of regular use – that works for me and my honest approach to the furniture.
