ᐅ How strong are the shelves in Ikea PAX wardrobes?
Created on: 29 May 2024 08:37
narsan
narsan
29 May 2024 08:37
I am currently planning a new walk-in closet and am particularly interested in the Ikea PAX system. My main question is: How strong are the shelves in the PAX system?
I understand that Ikea generally designs furniture for everyday use, but I want to use the shelves specifically for relatively heavy items like thick books, heavy binders, or smaller household appliances. Since the PAX modules are customizable, it would be helpful to know the realistic load limits and if there are any special recommendations for improving stability (e.g., additional reinforcements or specific installation techniques).
Does anyone know the exact technical specifications, have experience, or has tried similar applications and can share whether the PAX shelves are really suitable for heavier loads?
Thanks and best regards!
benon
29 May 2024 09:42
Hello narsan,
your question about the load capacity of Ikea PAX shelves highlights a common concern with this system: it looks sturdy at first glance, but how strong is it actually?
Basically, the PAX shelves are made of medium-density fiberboard (MDF) with a melamine coating, which makes them appear quite robust. According to the manufacturer, the load capacity per shelf is about 15 kilograms (33 pounds) when the shelf rests on the usual cutouts or brackets and the distance between the supports is not too large.
This corresponds roughly to the weight of a stack of books, but for very heavy loads (e.g., many file binders, tools, equipment) it may be wise to consider reinforcement options. For example, additional center supports or side brackets can help distribute the load.
I would recommend carefully checking the load and, if necessary, avoiding loading the shelves to their maximum capacity. If you plan to store such heavy items frequently, metal shelves might be an alternative or at least some form of reinforcement as you mentioned.
It is also important to distribute the load evenly: evenly spread loads cause less sagging.
I hope this helps with your planning. If you like, I can provide more information about reinforcement options.
Domau0
29 May 2024 14:28
Hello narsan,
I find your question very relevant, especially when considering PAX shelves for heavy loads. I have a PAX system myself with multiple shelves that I use for books and electronics, so I can share some details from my own experience and technical knowledge.
First of all, the spacing between the shelf supports plays a crucial role in load capacity. Ikea often specifies 70 cm (28 inches) as the standard maximum width, meaning the greater the distance, the more the shelf will sag under load. With a length of 50 cm (20 inches) or less, you can increase the load capacity, but caution is advised for 80 cm (31 inches) or more.
The MDF boards used for the shelves tend to sag slightly in the middle under heavy load. Additional center supports or metal brackets that you can mount on the back panel of the cabinet help a lot here. Another option is to reinforce the shelves with a thin strip under the front edge, which significantly improves stiffness.
If you plan to store heavy books or binders, also pay attention to the installation: the shelf supports need to be securely fitted into the side panels, preferably metal rather than plastic. Sometimes it helps to reinforce the side panels internally with extra screws or braces.
In summary:
- Maximum load usually around 15–20 kg (33–44 lbs) per shelf
- Load capacity strongly depends on the span (distance between supports)
- Reinforcements (center supports, brackets) recommended for heavy loads
I’m curious, how deep are your shelves planned to be? And how exactly do you intend to distribute the load?
benon
30 May 2024 07:53
Domau0 schrieb:
I have a PAX system myself with several shelves that I use for books and also electronics, so I can share some details from my own experience and technical perspective.
This immediately adds an important practical viewpoint!
From a technical perspective, I would add: a common mistake is to support the shelf only at two points, which quickly brings it close to its load limit.
If possible, the usable height can be reduced and additional shelf supports installed (e.g., in the middle) to better distribute the load and minimize sagging.
As Domau0 already mentioned, angle brackets or small metal strips underneath or on the sides also help.
Also keep in mind that the shelves in PAX systems are generally designed for typical household use; if you need higher load capacity, additional reinforcements are almost indispensable.
If anyone has experimentally tested the load capacity or has tips on tolerances, that would be very interesting to hear!
Ankeli
30 May 2024 12:17
I mainly use PAX shelves for clothing and light storage, but I have occasionally had stacks of books on them.
- Load capacity is about 15 kg (33 lbs)
- With too much weight, they bend and you can quickly see a sag in the middle
- Reinforcements like metal brackets help but are not included as standard
If heavy loads are planned, it is better to opt for more stable or specially reinforced shelving systems.
LOGEMIN
31 May 2024 09:04
I would like to add a few structured tips regarding the load capacity of the Ikea PAX shelves:
1. Material and Load Capacity:
- Ikea uses MDF boards in PAX system shelves, with an approximate load capacity of 15 kg (33 lbs) per shelf, distributed evenly across the entire surface.
- The load capacity depends on the shelf’s width and depth as well as the number of supports.
2. Installation and Reinforcement:
- Make sure to insert the shelf supports carefully into the designated holes to avoid unnecessary stress points.
- Additional center supports or brackets can be installed to better distribute loads and minimize sagging.
3. Usage Recommendations:
- Always distribute heavy loads evenly to prevent localized overloading.
- For frequent loading and unloading of heavy items, it is advisable to use shelves or systems made from metal.
4. Common Issues:
- Shelves that are too wide or too deep tend to sag more easily.
- Uneven loading or stacking of heavy items on one side increases the risk of failure.
I hope this helps everyone who prioritizes stability! For heavy loads, I would recommend avoiding experiments and instead reinforcing the shelving or using additional inserts made from more robust materials.
