ᐅ How durable are Ikea Brimnes furniture pieces after frequent moves?
Created on: 3 Nov 2019 09:21
san64Hello everyone,
I have recently been thinking about whether Ikea Brimnes furniture is really stable enough for frequent moving. I own several pieces from this series and, due to my job, I move quite often—on average every 1-2 years. I am interested in how the quality and stability of Brimnes furniture hold up with such frequent assembly and disassembly.
In particular, I would like to know if there are typical weak points that are especially affected by repeated dismantling, or if the furniture generally remains sturdy. Are there any experiences regarding whether hinges, dowels, or joints tend to weaken over time? Also, how can the lifespan realistically be assessed when regularly taking the furniture apart and putting it back together?
It would be great to hear from people who have moved often themselves and use Ikea Brimnes. Thanks in advance!
Hello san64,
I’m happy to provide a more structured answer to your question. With furniture like the Ikea Brimnes, the material and construction play a key role in their durability during multiple moves.
- First, the furniture is mainly made from particleboard, which is coated with melamine but not solid wood. This makes it lighter but also more prone to damage when disassembled frequently.
- The fasteners are often made of plastic or low-quality metal, which can loosen over time, especially dowels that tend to spread and no longer fit together properly.
- Hinges are usually sturdy enough, but quality matters here as well. There have been cases where screws stripped or pulled out after repeated reassembly, particularly if attached components were overloaded.
My advice is to always handle with care, avoid using force when taking the furniture apart, and replace screws, nails, and dowels whenever possible. Also, use the furniture carefully after assembly to prevent additional stress from improper loading.
In summary: Brimnes furniture is fine for a few moves, but frequent disassembly will noticeably wear it down. If you move very often, it’s best not to overstrain it.
SUDAN schrieb:
Brimnes furniture is acceptable for occasional moves, but frequent disassembly noticeably wears it out.I completely agree. It works fine for every few years, but if you take it apart often, problems arise.
I believe it is important to also consider the manufacturer's warranty and relevant test results. Ikea does not provide an explicit warranty for Brimnes that covers frequent disassembly. Additionally, chipboard products are inherently limited, especially with repeated assembly and disassembly.
Therefore, one should not rely solely on user reviews but understand clearly that furniture like Brimnes is not designed as moving furniture. This is part of the price-performance trade-off. Those who still choose this model and move frequently should be aware that premature wear is likely.
Alternatives made from solid wood or modular systems designed for frequent assembly may be worth considering.
In addition to the previous posts: I can confirm that frequent disassembly especially puts a lot of strain on dowels and connector holes. Chipboard tends to tear or splinter after several assemblies, which reduces the fit accuracy and weakens the stability.
The melamine coating also suffers from repeated dismantling and reassembly, causing cosmetic damage that mainly affects the resale value.
My tip: Anyone who moves frequently should check the original connections after each disassembly, replace any worn dowels or screws if necessary, and touch up with appropriate wood glues. This can significantly extend the lifespan.
