ᐅ How is a wall mounting done correctly for the Ikea Brimnes?
Created on: 16 Jun 2024 08:37
Dante30
Dante30
16 Jun 2024 08:37
Hello everyone, I have a specific question about wall mounting the Ikea Brimnes because I encountered some uncertainties while assembling my new cabinet.
Specifically: How do you correctly mount the Ikea Brimnes to the wall to ensure the cabinet is stable and securely fixed?
I’m especially interested in how to use the included wall fasteners, how to determine the correct position for the screws, and what to pay attention to regarding the wall material (e.g., drywall/plasterboard vs. concrete).
Additionally, it would be great to know if there are any special tips or recommendations that Ikea might not detail extensively but are important in practice to prevent the cabinet from tipping or sliding.
I have read that anchoring to the wall is not only mandatory for safety reasons but also significantly improves overall stability. Thanks in advance for your detailed tips and advice!
Kinbu
16 Jun 2024 09:15
Hello Dante30,
your question is very well phrased and important because mounting Ikea Brimnes furniture on the wall correctly does require some details that are not always obvious at first glance.
Basically, the Brimnes furniture comes with a wall mounting bracket, which usually consists of a safety part and screws designed to prevent the wardrobe from tipping forward. This safety feature should definitely be used and firmly anchored into the wall.
For the wall mounting, there are different hooks and anchors for various wall types: for concrete, brick, or drywall, you should use appropriate anchors. With drywall, you need to ensure that you either use special cavity anchors or, if possible, screw directly into a wall stud (e.g., wooden batten) to provide better support.
An important tip is to determine the exact position for the screws: it’s best to place the wardrobe at the desired spot first, use a spirit level to check, and mark the height so that the wall bracket fits precisely onto the corresponding part of the wardrobe.
Then you drill the holes for the anchors at those points, insert the anchors, attach the wall brackets, and finally hang the wardrobe by hooking or screwing the parts on the back of the wardrobe into the wall brackets.
Make sure, above all, that the screws are always tightened securely and that the attachment points on the wardrobe are not damaged to maintain stability.
If the wall mounting is used and the correct anchors are applied, the installation is safe.
I hope this helps you!
likuken
16 Jun 2024 09:47
Kinbu schrieb:
When it comes to wall mounting, there are different hooks and anchors for various wall types: for concrete, brick, or drywall, you should use the appropriate anchors.
The issue with anchors is actually the key point. I always view it critically when someone just uses the standard anchors that come with Ikea furniture, because most of those kits don’t take the wall type into account. Especially with drywall, I would recommend using at least hollow wall anchors or alternative fixings; otherwise, you won’t get a secure hold.
Also, keep in mind that the Brimnes wardrobe is often filled and heavy, so a weak anchoring can quickly become insufficient.
What’s even more interesting is that Ikea only requires the furniture to be secured to the wall for safety reasons, but they don’t provide an official system for full wall mounting – it’s more of a standard safety step. Whether the installation actually holds perfectly in practice depends a lot on workmanship and choosing the right anchors.
Sometimes it might even be better to use your own, stronger fixings or at least upgrade the standard mounts. Ikea may be trying to cut costs, but safety has its price!
So the question is how much effort you want to invest to ensure the wall mounting for the Brimnes really holds securely and not just “barely holds.”
flo-Theres
17 Jun 2024 11:03
likuken schrieb:
Sometimes it might even be better to use your own, stronger fasteners or at least upgrade the standard brackets.
That is a very good point. I would add: Choosing the right wall plug is truly crucial, and it depends entirely on the type of wall. For concrete or solid masonry walls, heavy-duty anchors or metal expansion anchors are ideal, which Ikea does not typically include by default.
For drywall (plasterboard) walls, it is essential to use cavity anchors or special toggle bolts, as simple plastic anchors provide little support there.
The screws that go directly into the cabinet usually fit into pre-drilled holes. It is important to install the supplied metal brackets or anti-tip devices correctly, to prevent the cabinet from tipping over, even under pressure or load.
One more tip: Before drilling for the final install, carefully check the position—preferably using a spirit level or even a laser level—to ensure the cabinet is mounted perfectly straight. Also, having someone hold the cabinet steady while attaching the wall fasteners is very helpful.
These additional care steps make the installation much safer.
Kinbu
18 Jun 2024 07:26
Dante30 schrieb:
I am particularly interested in how to use the included wall mounts, how to determine the correct position for the screws, and what to pay attention to during installation regarding the wall type (e.g., drywall versus concrete).
One more helpful tip for positioning: the wall brackets are usually attached to the back of the cabinet, near the top.
- Place the cabinet in the planned location.
- Measure the height where the metal brackets or anti-tip device connect.
- Mark the drill holes precisely on the wall.
If the wall is drywall, check if there is a supporting timber batten or stud nearby – this is the ideal place to screw in the screws, as it makes the bracket much more secure.
If there are no battens or studs, high-quality cavity anchors are the way to go.
likuken schrieb:
I am always skeptical when someone simply uses the standard anchors that Ikea provides.
I can only agree with that: if you want to be on the safe side, you should upgrade the set, especially since the cabinet holds a lot of weight and often moves when opening doors or drawers.
This reduces the risk of screws loosening or damage to the wall.
