ᐅ How does the quality vary between different BILLY batches?
Created on: 31 Jan 2024 13:04
Akimmar
Akimmar
31 Jan 2024 13:04
I have recently noticed discussions about the quality of the BILLY shelves varying significantly between different production batches. My question is: How exactly does the quality differ between various BILLY batches?
I am particularly interested in whether there are noticeable differences in materials, workmanship, fit, and stability that consumers should be aware of when buying newer or older batches.
Are there any known batches that are clearly better or worse? Are there specific details in the manufacturing that can help identify the batch quality?
I look forward to well-informed answers supported by experience or concrete facts.
KLO-KA
31 Jan 2024 13:19
The quality does fluctuate at times. Older batches tend to have better stability, while newer ones are often made thinner. When it comes to fit, you should check the side trims – some batches have more play there.
Fitigu
31 Jan 2024 14:02
Studies and user reports indicate that from around 2022, the wooden panels used in BILLY shelves have become thinner, reducing their stability. There are also reports of lower-quality edge banding compared to previous years.
A key distinguishing feature is the internal finishing of the back panels: newer batches have been produced slightly thinner, which limits their load-bearing capacity.
Recommendation: When buying in-store, try to choose a model from a well-reviewed batch or, if in doubt, opt for units from before 2022.
Akimmar
31 Jan 2024 14:46
KLO-KA schrieb:
Older batches tend to have better stability, newer ones are often made with thinner materials.
Thank you for the tip. Are there any reliable sources or tests that confirm this? I’m asking because I have two BILLY shelves, one from 2018 and one from 2023, and they actually feel different in terms of material.
I’m also curious whether there are systematic differences in the fittings or screws that could affect assembly quality.
Does anyone have experience with this?
CHENFAR
31 Jan 2024 15:10
Regarding material thickness: Official specifications for panel thickness are no longer detailed by IKEA itself. Consumer tests and user forums, however, consistently indicate that newer batches of BILLY shelves often show a reduction in panel thickness by approximately 1 to 2 mm (0.04 to 0.08 inches).
Fittings and screws remain mostly unchanged, but thinner material has been used on the inside of the back panels, which can affect the overall stability of the construction.
Akimmar schrieb:
Are there systematic differences in the fittings or screws?
The screws are generally identical; there are only minor differences in the material of the connecting screws.
nubar
1 Feb 2024 09:33
An important observation I have made from repair work on BILLY shelves is that the edge banding glue quality has declined in more recent batches. This results in faster chipping or peeling under stress or during moves.
The issue mainly affects the visible edges on doors and shelves, which can lose stability with heavier use.
For users planning to use the shelf long-term, this is an important factor to consider when choosing a specific batch.
