ᐅ How does the installation of Ikea Metod corner carousels work?
Created on: 27 Feb 2023 10:23
SarpsuHello everyone,
I want to install the Metod corner carousel in my new Ikea kitchen and have some questions regarding the installation. Specifically, I’m interested in how to correctly assemble the individual components and, above all, what to pay attention to during assembly to ensure the corner carousel works smoothly later on. I would also like to know if there are any special tips to make the most of the tricky corner, such as through adjustments or specific settings.
I am familiar with the basic Ikea instructions, but I find them somewhat unclear, especially regarding the fastening and hanging of the rotating shelves. Are there any experiences with the parts’ fit or advice on handling the hinges and locking mechanisms?
Thank you in advance for your help!
Hello Sarpsu,
For installing the Ikea Metod corner carousel, I recommend reading the entire assembly manual first, even if it seems brief at times. Important points include:
- The side panels of the base cabinet must be set precisely at 90 degrees, otherwise the carousel will not fit flush.
- The guide rails for the rotating shelves should be properly secured with the included mounting hardware to ensure smooth rotation.
- Before completing the assembly, carefully check the alignment of the carousel shelves—they should turn freely but not be too loose.
A common mistake is overtightening the fixing screws, which causes the rotation mechanism to jam. It’s better to start with them loosely tightened, then gradually tighten step-by-step while checking frequently.
If you have any questions about specific steps, feel free to ask.
Rashadmeo27 Feb 2023 16:37Great that you want to install the Metod corner carousel! It’s a really practical solution to make good use of that boring corner space.
At first, I was also unsure if I could manage it, but the nice thing is that the components are very well designed! 🙂 The key is to take your time and work step by step.
A small tip: At first, screw the carousel shelves in loosely and test how the basket rotates before tightening everything up for good. After a few fine adjustments, mine worked perfectly, and I didn’t want to stop spinning the basket!
You can do it—feel free to reach out if you need some motivation!
Hello Sarpsu,
I’m happy to provide you with a more detailed guide based on my experience with the Metod corner carousel:
1. Preparation:
- Measure: Ensure that the base cabinet area is exactly rectangular and the height is level.
- Clean the surfaces where the carousel components will be installed.
2. Installing the bottom and top guide rails:
- First, install the floor and ceiling rails according to the instructions.
- Make sure the rails are mounted exactly parallel to each other.
3. Hanging the rotating shelves:
- Place the shelves on the central axis; they should turn smoothly but without wobbling.
4. Fine adjustment:
- Check that the carousel does not touch the cabinet except at the mounting rails.
- Adjust if necessary using the included washers or screws.
5. Final securing:
- Tighten all screws firmly by hand, avoiding overtightening.
Common mistakes:
- Cabinet walls not perfectly aligned.
- Screws too tight, causing the rotation mechanism to jam.
- Missing adjustment at the central axis.
I hope this helps you. Some IKEA furniture simply requires precision during assembly, especially corner carousels.
1. Preparation:
4. Fine adjustment:
5. Final securing:
Common mistakes:
klo40 schrieb:
3. Installing the rotating shelves:
- The shelves are placed onto the central axis and should rotate smoothly, but without wobbling. I would like to add to this point: The central axis is the key component of the Metod corner carousel. It must be securely and evenly positioned to prevent any play and unwanted movement. If the basket feels too loose, rubber buffers or small spacers can be used to improve stability.
Additionally, it is important to note that the threaded rods on the central axis sometimes need to be carefully bent or adjusted. Although Ikea manuals rarely address this directly, in kitchens with precise wall alignments, this often makes a noticeable difference.
In summary: Accurate alignment and adjustment of the axis are more important than most realize. Otherwise, the carousel will work but cause annoyance due to play or sticking.
