ᐅ How can IKEA HEMNES furniture be disassembled without causing damage?
Created on: 8 Mar 2024 08:37
Lule66Hello everyone, I would like to start a detailed discussion on the topic “How to disassemble IKEA Hemnes without causing damage?”
I am especially interested in how to take apart the individual components—whether drawers, side panels, or back panels—so that nothing breaks, warps, or small parts are lost. It would also be helpful to learn about common pitfalls to avoid and tips on the ideal tools to use.
Are there specific sequences or tricks for loosening screws and connectors without breaking them or wearing out the threads?
I already have some experience with disassembly, but I have particular respect for the Hemnes pieces, which often consist of solid wood, and I want to make sure the furniture doesn’t end up unusable.
I’m looking forward to helpful advice from the community!
First, pull out all the drawers and remove the bottom panel. Systematically loosen the screws, preferably using a suitable screwdriver to protect the threads. Carefully pry off the back panel, which is often just stapled. Never unscrew the screws with too much force, as this can cause them to strip.
To disassemble IKEA HEMNES furniture, it is important to avoid breakage in the solid wood by consistently relieving stress and preventing tension during dismantling. It is recommended to first completely empty the furniture and systematically loosen all visible screws using a narrow, appropriately sized screwdriver or a cordless drill set to low speed.
The sequence should be:
- Remove the drawers completely first.
- Loosen the side panels at the connections to the back panel and base.
- The back panel is often attached with staples or thin nails, which should be carefully removed with a flat tool to prevent cracks.
- For all screws, using the original Allen key or Phillips screwdriver is ideal to protect the screw holes.
Another recommendation is to store all small parts immediately in small bags or boxes to prevent loss. It is also best to label the screws by position in case there are questions during reassembly.
Avoid applying force or excessive pressure on the wooden parts, as they could otherwise splinter.
usbla schrieb:
One should avoid using force or excessive pressure on the wooden parts, as this could cause them to splinter.I completely agree. Some time ago, I was impatient and handled a side panel a bit too roughly, which caused a small crack – that can be really frustrating.
It really helps to keep in mind that every piece of furniture needs some care, both when taking it apart and when assembling it. I have developed the habit of first locating all screws before starting to remove them one by one, never just pulling or prying.
Once everything is properly prepared, you can disassemble calmly and save yourself the cost of repairs.
Have you ever used special protective measures when dismantling, such as covering edges or inserting felt or rubber pads to cushion leverage points?
For disassembling the IKEA HEMNES series, I recommend a structured approach and paying attention to common pitfalls that can cause damage.
1. Preparation:
- Make sure you have all the necessary tools ready: an appropriate Phillips and Allen screwdriver, and possibly a plastic scraper to remove the back panel nails.
- Prepare containers for screws and fittings, preferably labeled.
2. Disassembly order:
- Take out the base panel or shelves.
- Then detach the side panels from the front and back panels.
- Carefully remove the back panel using a plastic scraper to avoid splintering. The back panels in HEMNES models often have thin staples or small nails, which should never be pried off with metal levers.
3. Common mistakes and how to avoid them:
- Do not use the wrong screwdriver, as this will round off screw heads.
- Avoid turning screws at an angle or forcing them out.
- Using excessive force when levering joints often causes wood parts to break out.
4. Aftercare:
- Store all screws and dowels separately, and secure the smallest parts immediately.
Summary: Patience and using the right tools are key. It is better to proceed slowly and carefully, especially with solid wood parts, to avoid cracks and dents.
1. Preparation:
4. Aftercare:
