ᐅ How do you dismantle Ikea Hemnes shelves step by step?
Created on: 18 Feb 2020 10:12
Timako
Timako
18 Feb 2020 10:12
I would like to know how to dismantle Ikea Hemnes shelves step by step. Specifically, I am interested in which tools I need, the best way to take apart the individual components, the optimal order to follow, and what to pay special attention to in order to avoid damage.
The reason is that I want to disassemble the shelf to move it, but I have no idea whether I should simply reverse the assembly process or if there are particular tricks. It would also be helpful to know how to safely remove any embedded screws, dowels, or connectors.
I have the standard Hemnes shelf, 80x190 cm (31.5x74.8 inches), painted wood, with no additional modules. A detailed step-by-step guide would be great, ideally with tips on small problem areas that might be easily overlooked.
Thank you all for any help!
Rhett
18 Feb 2020 11:05
You need a Phillips screwdriver, preferably magnetic.
1. Remove the shelves.
2. Carefully take off the back panel (usually fixed with nails).
3. Detach the side and back panels by removing the screws.
4. Always unscrew the fasteners; do not pry to avoid damage.
Lilygla
19 Feb 2020 08:47
I like to approach this very thoroughly because Hemnes shelves have a few small tricks that you should be aware of.
- First, remove all the shelves. In Hemnes units, the shelves are usually just laid in place, so hold them securely to prevent tipping.
- Next, remove the back panel. This is usually fixed with small nails, sometimes with thin staples. Use a flat spatula or a nail puller to carefully loosen it. Be cautious here to avoid splitting the wood.
- Now, take off the side panels as well as the top and bottom crossbars. In Hemnes units, these connections are usually secured with dowels and screws using cam lock fittings. You need to unscrew the screws with a Phillips screwdriver; sometimes they are recessed, so remove the plastic covers beforehand. It’s important to fully unscrew the screws before pulling the parts apart to prevent damage.
- When pulling the parts apart, dowels might stay stuck since you cannot always see them. Carefully loosen them with a small screwdriver and avoid using force.
One tip: If you plan to disassemble the shelf for later reassembly, number the parts and take photos of how the connections look. This will save a lot of searching later on.
What does your current setup look like? Is it placed against a wall or free-standing? This can affect how easily the back panel can be removed.
Timako
19 Feb 2020 09:56
Lilygla schrieb:
What does your current setup look like? Is it placed against a wall or freestanding? That can affect how easily the back panel can be removed.
Thanks, that’s a helpful tip. The shelf is freestanding in the room, not fixed to a wall. The back panel is fully visible, with no covering in front. That should make it easier to remove the back panel.
I will follow your steps and mark the parts where possible. How exactly can I handle the dowels? Sometimes they get stuck in the holes. Is there a method to remove them as gently as possible?
Does anyone have tips or tricks specifically for the wooden joints on Hemnes?
Dwight49
20 Feb 2020 14:38
As an addition: Hemnes shelves usually use traditional wooden dowels and cam lock screws.
Here is the recommended approach:
- Completely remove the screws without prying them out.
- If dowels remain stuck, carefully try to lever them out of the holes using a thin screwdriver.
- Alternatively, applying a light oil to the dowels can help if they are tight.
- Make sure no components become misaligned to avoid damaging the wood.
Additionally, a stable surface during assembly and disassembly is advisable to prevent warping.
Depending on the age of the furniture, the screws may be tightly secured. It is important to work gently to avoid damaging the material.
rebufar
21 Feb 2020 07:24
Rhett schrieb:
Always loosen screws instead of prying; this prevents damage.
I think this statement is almost a truism. Of course, you shouldn’t pry—but honestly, IKEA furniture is designed so that you can sometimes separate the pieces with gentle force if you know exactly where to push or pull.
The point is more that if you strictly follow every single step exactly, you are probably already approaching the task the wrong way. IKEA doesn’t produce museum exhibits.
If you want to take the shelving unit apart properly, in my opinion you shouldn’t be overly cautious, but rather pragmatic. Sometimes a rubber mallet or a small piece of wood as a protector can be helpful when prying, as this lets you loosen connections without spending a long time turning screws that can occasionally be stuck.
Discussion: Isn’t this basically what IKEA intends with their supposedly simple assembly? That you don’t have to be too precise?
