ᐅ How can IKEA Platsa furniture be converted into a corner configuration?
Created on: 20 Dec 2024 08:17
jonman
Hello everyone, I am currently planning to convert my IKEA Platsa furniture into a corner configuration and have noticed that there is no clear instruction for this. I am particularly interested in how to connect the individual modules so that they are stable on one hand and at the same time make optimal use of the typical corner shape. Which connection methods are recommended to securely join the Platsa units together? Are there any special considerations regarding the back panels or the installation of doors when the furniture is placed together in a corner? In general, I would like to understand how the conversion of IKEA Platsa into a corner solution works: from measuring to final assembly. I appreciate any practical tips, experiences, or do’s and don’ts!
Domau0
21 Dec 2024 10:05
jonman schrieb:
This is a corner in the living area that is used both for storage and as a room divider.
This raises a few additional considerations. If the corner unit also functions as a room divider, it makes sense to make the back panel facing the room as visually appealing as possible. Standard back panels are often just particleboard or thin material and not designed to be seen.
You have two options here:
- Replace the back panels with decorative boards (e.g., MDF with veneer) cut to size.
- Or build an additional cladding over the back panels.
Furthermore, the connection should be strong enough, as room dividers are often subject to greater stress, for example, as surfaces to place items on.
Regarding the floor: If your floor is slightly uneven, be sure to check with a spirit level in all directions before installation, and use small adjustable feet or cork pads under the legs to compensate for any irregularities. This results in even load distribution and a more stable furniture assembly.
likuken
21 Dec 2024 11:45
Filippo schrieb:
You should cut the back panels so that the cut edges meet exactly at the corner, with no gaps. This increases stability.
You’re forgetting that we’re talking about IKEA boards here. In everyday use, those precise adjustments can easily get lost if the back panels aren’t fixed or otherwise secured.
I would advise you not to spend too much effort trying to make perfect back panels, but rather invest in flexible solutions like clamp strips or even hook-and-loop fastening systems for the back panel. This way, you can adjust the storage space, remove doors as I already suggested, and quickly change the inserts without causing any damage.
A corner stays a corner, but at least the furniture should remain flexible.
jonman
22 Dec 2024 09:18
Thank you for the extensive and helpful discussion! I will try using precise measurements, properly cut back panels, and sturdy metal brackets. The advice regarding the door opening radius is very useful and will help me plan spacers right away. For the floor, I will use small adjustable feet. I also appreciate Domau0’s suggestion to consider a more attractive back panel side for the room divider. I will get back to you as soon as I make further progress.
