ᐅ How can IKEA Platsa furniture be converted into a corner configuration?
Created on: 20 Dec 2024 08:17
jonman
Hello everyone, I am currently planning to convert my IKEA Platsa furniture into a corner configuration and have noticed that there is no clear instruction for this. I am particularly interested in how to connect the individual modules so that they are stable on one hand and at the same time make optimal use of the typical corner shape. Which connection methods are recommended to securely join the Platsa units together? Are there any special considerations regarding the back panels or the installation of doors when the furniture is placed together in a corner? In general, I would like to understand how the conversion of IKEA Platsa into a corner solution works: from measuring to final assembly. I appreciate any practical tips, experiences, or do’s and don’ts!
I would like to disagree, because precision is especially important when it comes to corners. If you don’t fit the back panels exactly to the corner, you won’t have a sufficiently stable structure. A back panel that doesn’t sit flush causes a loss of stability along the battens, which later results in wobbling or even tension stresses in the furniture.
Regarding the procedure:
- First, measure the exact area with an angle measurement tool.
- Then cut the back panels precisely with a jigsaw – the material cut also plays a crucial role in the fit accuracy.
- For connecting the modules, concealed furniture connectors (e.g. “ZIP” connectors) are particularly suitable.
- Check the door edges and stop areas for compatibility; spacer wedges may be necessary if required.
In some cases, the effort is worth it, not only to reduce dust but also to significantly increase the service life and usability of your furniture.
likuken schrieb:
Man macht es sich unnötig schwer.
likuken schrieb:
I see it differently when it comes to doors: IKEA doors are not superior anyway, so simply leaving out the doors on one side avoids any problems with opening.That might be a practical solution, but it significantly limits usability. Especially with a well-designed corner setup, full use of all doors is desirable, so it is worth the effort to use appropriate hinges or spacers.
Regarding the back panels in the corner: As Filippo already mentioned, a poor fit can quickly lead to instability. The back panels contribute significantly to lateral stabilization, especially for units connected at the corner. Even small gaps caused by imprecise cutting or incorrect angles can noticeably reduce overall stability.
Therefore, I recommend:
- precise measuring
- careful cutting of the back panels
- corner brackets or screws inside the corner area
- possibly additional securing of the back panel to the cabinet sides
What exactly is the shape of your corner, jonman? Is your wall a perfect right angle, or are there deviations?
Here is a summary with additions:
1. Use a precise protractor to measure angles and identify deviations.
2. Assemble Platsa modules individually, then secure them with metal corner brackets.
3. Adjust back panels at corner locations accurately using a jigsaw, or install special replacement back panels.
4. Check that doors operate properly against each other; modify hinges if necessary.
5. Use washers to compensate for minimal angle deviations.
6. For additional stability, connect individual panels indoors with angle brackets.
These steps help minimize later issues caused by wobbling or misaligned doors.
Thank you for the feedback! I am currently planning two sides, each 180 cm (71 inches) long, so probably three modules 60 cm (24 inches) wide per side. The corner is a precise right angle. I want to build the furniture as stable as possible but also maintain full functionality of the doors – so any advice on hinges is greatly appreciated. This is a corner in the living area, used both as storage and as a room divider. Is there anything special to consider regarding floor leveling? The floor is slightly uneven, which might affect stability. Can I achieve sufficient flexibility by using special connectors or spacers?
For 3 modules per side, you can proceed as follows:
- First, place all modules individually against the wall, leveling them precisely with a spirit level and, if necessary, small wedges to achieve accurate alignment.
- For the corner connection, I recommend using flat angle brackets on the inside, screwed in with the longest possible screws to ensure a strong and durable joint.
- The back panels should be cut so that the cut edges meet exactly at the corner without gaps. This increases stability.
- Regarding the hinges: if the doors meet directly at the corner, check whether the hinges interfere or can open properly. There may be hinge extensions available, or you can install spacers (e.g., wooden strips of 3-5mm (0.1-0.2 inches)) between the modules to increase the gap.
- On uneven floors, it is advisable to level all modules with small adjustable feet or wedges. This prevents rocking and uneven stress that could strain the corner connectors.
- In general, the back panels combined with the corner brackets provide the necessary stability for the structure if everything is done carefully.
If you are working with modules of different depths, it is somewhat more complex; with identical dimensions, it is fairly easy to calculate.
