ᐅ How can IKEA PLATSA furniture be adapted to fit under sloped ceilings?
Created on: 30 Jan 2024 09:17
X
xhulio30Hello everyone,
I am planning to furnish my sloped ceiling area with IKEA Platsa furniture, but I am unsure how the adjustment to the slope works technically. Specifically: How can I configure the Platsa series so that the furniture fits perfectly under a sloped ceiling? What options are there to flexibly adjust the fronts or dimensions to accommodate irregular inclines? Do I need to cut parts manually, or are there prefabricated options or special components in the system designed for sloped ceilings?
Additionally, I am interested in how stable these adaptations are and if there are any experiences with handling unusual room angles.
I would appreciate detailed explanations or tips, preferably including an assessment of effort and materials. Thank you in advance!
Hello xhulio30,
Your question about adapting IKEA PLATSA furniture to sloped ceilings is very practical and important for a precise fit.
Basically, PLATSA is a modular system that can be flexibly assembled from various elements. However, most modules come in standard sizes and do not account for sloped room edges by default. Several steps are important here:
- Measurement: First, you need to accurately measure the actual angle and height of the sloped ceiling. Using an angle finder or a precise laser distance meter is often recommended.
- Module planning: In the IKEA planner or with the PLATSA app, you can create floor plans and combine individual cabinets, but there are no standard parts for sloped edges.
- Adjustments to fronts: It is often necessary to cut the fronts or side panels because the sloped ceiling does not meet at a 90-degree angle. You can either shorten baseboards or shelves accordingly or use solid wood/plywood panels, which you cut diagonally and enhance with decorative veneers.
- Construction with flat angle brackets or angled cuts: To integrate the slopes visually in an elegant way, angled connectors are recommended, and possibly installing custom-cut sloped ceiling panels that are then attached with hinges.
- Stability: For support on the roof, you should additionally fix the modules to the walls or ceiling, even though the PLATSA elements are fundamentally stable. When adapted to sloped surfaces, the installation effort increases.
- Experience: Many users create custom-fit covers or sloped side panels from MDF or plywood, which they then paint or laminate. This increases individuality and durability.
In general, it is recommended to use standard PLATSA elements as a base and customize all special shapes as needed. I hope this helps you so far. Would you like to measure your sloped ceiling and post the dimensions? Then we can suggest specific modules.
KLO-KA schrieb:
Ikea does not offer specific angled fronts, so you have to cut them yourself or have a carpenter adjust them.Exactly, and I’d like to add: For the cuts, you should definitely choose good quality material to prevent the edges from fraying or absorbing moisture later on.
Additionally, you can use hinges or flaps with gas springs to make angled doors easier to operate. This is especially helpful for angles near the bottom.
One more tip: In the PLATSA system, you can optionally combine open compartments that are easy to customize. Side panels can be secured with sturdy brackets to ensure everything stays stable, even with irregular angles.
It’s worth measuring the space precisely with a tape measure and level, because even a small millimeter error quickly becomes noticeable gaps with sloped ceilings.
What is the approximate angle of your slope, xhulio30? The steeper the slope, the more complex the adjustment.
Hey xhulio30 – I know this topic from personal experience! The PLATSA furniture is really easy to customize if you have some DIY skills. It worked great for me because I carefully drew the slanted parts on paper during the planning and then simply cut the fronts diagonally.
I can only say: go for it, the result is really cool and very unique! 🙂
I even covered the cut edges with special tape to make it look professional. And yes, stability is important – that’s why I fixed the units to the wall and ceiling with angle brackets.
If you have any questions about tools or materials, just reach out, I’m happy to help! It’s really fun to see how you can turn the system into something unique.
