kenmarieke25 Aug 2019 09:37Hello everyone,
I have an issue with an IKEA Malm bed that starts to wobble and feels less stable after some time. This is especially common with older models when the joints become a bit loose or the screws are no longer fully tightened. I’m looking for simple and practical ways to make these beds more stable with minimal effort and without needing special tools.
My question is: What are the best ways to stabilize Malm beds using basic means, without having to buy new parts or specialized tools? What tips or tricks have worked for you to reduce wobbling permanently?
I look forward to your recommendations and experiences!
diManuela25 Aug 2019 14:19Hello kenmarieke,
I’m familiar with this issue. The Malm bed uses fairly simple joints that can loosen over time. The best approach is to first check all screws and wooden connectors, tightening everything carefully. This often prevents much of the movement.
If tightening isn’t enough, small wooden wedges or self-cut felt strips placed at the joints can help bridge minor gaps. It’s important not to make the wedges too thick to avoid unwanted distortion.
If you like, you can also apply wood glue to the joints for longer-term stabilization. However, glue shouldn’t be reapplied every two weeks ;-) — ideally only during a major repair.
Personally, I’ve been using washers under the screw heads when possible to better distribute the pressure, which improves durability.
If you have any questions about specific steps, I’m happy to help!
Sheldon schrieb:
First, make sure all the screws are properly tightened.
RonJarrett26 Aug 2019 08:53From a technical perspective, there are a few points to consider if you want to stabilize an IKEA Malm bed without making major investments:
1. Check the screws: Regularly tightening them with the appropriate Allen key reduces the looseness caused by material fatigue.
2. Use washers: These increase the bearing surface and prevent screws from sinking into the wood, whether accidentally or under load.
3. Additional wooden wedges or thin plywood strips can be attached at the contact points to fill any gaps.
4. If applicable, secure loose wooden dowels with wood glue.
5. If possible, place the bed legs on non-slip rubber pads to improve load distribution and prevent slipping.
This method is indeed effective but can be influenced by stresses from movement and climate conditions, so it should be regularly checked. It is important to avoid applying excessive force and instead make adjustments carefully.
If the bed still wobbles, realigning the individual frames might be necessary, which can be difficult without tools.
In summary: tightening, using washers, inserting wooden wedges, and adding non-slip pads under the legs – this should help in most cases.
diManuela schrieb:
If tightening isn’t enough, small wooden wedges or self-cut felt strips placed at the joints help bridge small gaps.
Hey kenmarieke and everyone else!
This topic is really important because a wobbly bed can be really annoying, but there are simple ways to fix it! 😊
I would definitely recommend, besides tightening the screws, to use rubber pads or felt gliders more often – not only on the legs but also at the joints. This reduces friction and provides slight cushioning! And honestly, if you gently tap the joints back into place with a small hammer and some wooden blocks, it can make a big difference!
Also: if you have a small tube of wood glue – perfect. But use it sparingly, or else things might stick the wrong way later and cause more trouble.
And don’t forget – with Malm beds, the slatted frame is often the “key.” When it fits properly, the whole bed stays more stable. So check if the slatted frame isn’t loose!
Good luck stabilizing it!! You can definitely manage it! 🙂
kenmarieke schrieb:
What’s the best way to stabilize Malm beds with simple methods, without having to buy new parts or special tools?
