ᐅ How can IKEA Hemnes beds be reinforced for heavy use?
Created on: 11 Jul 2020 09:37
nenano
nenano
11 Jul 2020 09:37
I have an IKEA Hemnes bed that we have been using very intensively for some time. Due to the frequent and heavy use, I’ve noticed that the bed is starting to feel a bit unstable—especially the headboard and footboard don’t seem as secure anymore, and it’s creaking increasingly. My question to the community is: How can an IKEA Hemnes bed be stabilized for heavy and continuous use so that the structure remains solid and durable over the long term?
I have already considered tightening some screws or adding extra reinforcements, but I would like to know if there are proven methods or tricks to properly stabilize the bed without completely disassembling or altering it. What materials, tools, or approaches are recommended for an effective and lasting improvement in stability?
Thanks in advance for your tips!
kenkeo
11 Jul 2020 12:16
Hey nenano! Great question, especially if the Hemnes bed is used a lot, stability is really important! 😊
For my own bed, I reinforced the wooden parts with some assembly adhesive and also secured the screws with thread locker – that way they don’t come loose anymore. Additionally, attaching felt pads to the feet can help reduce movement a bit.
If you want, you can also install metal brackets on the inside, fixed with small screws. This makes everything hold much better and practically eliminates wobbling!
Don’t hesitate to do a bit of DIY, it’s worth it! 💪
Palenar
11 Jul 2020 18:29
Hello nenano,
You raise a very relevant question regarding stabilizing the IKEA Hemnes bed under heavier use. I’m happy to share a detailed approach based on experience and technical accuracy.
First, consider the construction of the Hemnes bed: it is made of solid wood with joints mostly connected by screws and dowels. Frequent use and load can cause the screws to loosen and the wood around the joints to slightly give way, which results in wobbling.
My recommendations, step by step:
- Fully loosen the screws and apply wood glue to the joints to achieve a permanent bond.
- Then, reinsert the screws, using a cordless drill with torque control to ensure a firm fit without over-tightening.
- For even more stability, replace the screws with metal wing nuts where the construction allows.
- At particularly stressed points, such as the headboard and footboard, additionally install flat steel brackets. These can be mounted on the inside and provide higher resistance to twisting forces.
- I also always check the support surfaces for the slatted frame and mattress; if these are not fitting well, they can cause wobbling on the base. In such cases, inserting wooden dowels may help improve the fit.
One more question for you: How old is your bed and how intensively is it used? (e.g., single or double bed, daily use involving children, pets, etc.) This information could help tailor the stabilization more precisely.
Best regards!
Mekau
12 Jul 2020 07:42
Palenar schrieb:
Completely loosen the screws and apply wood glue to the joints to achieve a permanent bond.
In this case, be sure to let it dry thoroughly. This often works very well with Hemnes furniture.
I also recommend retightening the screws and checking them regularly.
kenkeo
12 Jul 2020 09:58
Mekau schrieb:
In this case, definitely make sure to let it dry thoroughly. This often works very well with Hemnes furniture.
Absolutely! And if you secure the screws with a bit of threadlocker, you won’t need to keep tightening them! 😎
One more tip: If you’re working with metal brackets, you can touch up the spots with wood stain or paint to blend them in—it looks great and is almost invisible.
This gives the bed excellent stability, especially with daily use, so no more wobbling!
