ᐅ How do you replace drawer slides in Pax wardrobes?
Created on: 11 Nov 2024 08:23
gertrud
Hello everyone, I am facing the challenge of reconstructing the drawer slides for my IKEA PAX wardrobe because one of the original slides is damaged, and replacement parts are currently difficult to obtain. My specific question is: How can drawer slides for a PAX system be recreated as accurately as possible or professionally replaced so that the drawers still operate smoothly and the wardrobe remains stable? I am particularly interested in which materials are best suited, how to take the measurements most accurately, and if there are any tips for fastening that should be considered during the reconstruction. I would appreciate detailed advice or practical experience!
gertrud
12 Nov 2024 07:18
Filippo schrieb:
Remove the existing rail completely and measure all individual parts separately (telescopic rail, rollers, etc.)
Good idea! I actually wanted to take a closer look at the rollers since the ones on the damaged track are broken.
Does anyone have tips on how to find suitable replacement rollers if you don’t want to rebuild the entire track but just replace individual parts? And how important are these small components for a stable, smooth, and jerk-free drawer operation?
Paunon
12 Nov 2024 08:05
Replacement rollers are often available as standard parts in hardware stores or online. You should pay attention to the diameter and width. It is important that they fit well into the track. Rollers are essential for smooth operation, so it is worth measuring carefully.
juMira46
12 Nov 2024 08:49
Yes, replacement rollers are the unsung heroes of cabinet construction! 😊 When they get stuck or worn out, you notice it immediately when opening – there’s creaking and sticking.
I would definitely try to find the right ball bearing rollers instead of just putting in any cheap, quick-fix rollers. A tip: When checking at hardware stores, take the old roller with you for comparison! A direct comparison is more helpful than any description.
And who knows: You might even find stainless steel rollers or ones with better coatings from spare parts suppliers for an especially smooth operation.
Jensson
12 Nov 2024 09:36
To effectively recreate or replace the drawer slides for Pax to ensure long-lasting durability, a structured approach is recommended:
- Step 1: Precisely document the original dimensions (length, width, mounting points)
- Step 2: Check the condition of the rollers and mark any wear
- Step 3: Replace missing or damaged components as needed (e.g., rollers, rails)
- Step 4: Choose materials for the rebuild (steel with zinc coating is durable)
- Step 5: Perform a test installation to verify smooth operation
The rollers are not a minor part; they significantly affect smoothness and stability. If they are damaged, I recommend replacing them or using complete rails with matching rollers. If you want to replicate the soft-close mechanism, this is a separate challenge because it involves dampers and springs.
Davidleo
13 Nov 2024 10:14
Super interesting topic! I really like that you want to rebuild the drawer slides yourself – it shows genuine craftsmanship and creativity! 😊
If it helps: If you can't find a suitable spare parts supplier, you might consider using a more universal drawer runner profile that can be adjusted in length and then secured inside the PAX frame with wooden wedges or special holders. It’s important to test the running smoothness and, if necessary, apply lubricant.
Keep your spirits up, you’ve got this! With a bit of patience, the drawers will be sliding smoothly again in no time.
