ᐅ How do you fix warped IKEA PLATSA doors?
Created on: 5 Mar 2021 18:23
baastian
Hello everyone, I noticed that one of my IKEA Platsa cabinet doors has warped slightly due to moisture and no longer closes properly. Does anyone have experience with how to straighten warped Platsa doors or at least repair them so they function again? I suspect the material swells when exposed to moisture, causing the warping, but I’m not sure if this can be fixed from the outside or if removing the door and using certain drying methods would be more effective. Are there any tips on special clamping techniques, or better yet, are there replacement parts available to swap out damaged sections? The cabinet is still relatively new, and I’d prefer not to replace everything right away. Thanks in advance for your advice!
Mufato
7 Mar 2021 16:04
Expand, allow to dry, and brace with wooden battens without applying excessive pressure. Check screws and hinges; otherwise, recommend replacement.
nubar
8 Mar 2021 10:59
Jamalli schrieb:
Basically, applying too much mechanical pressure should be avoided, as the MDF laminate can be unevenly stressed.
That is correct; balanced pressing is essential to avoid causing further damage. It should be added that before any repair, you must ensure that the source of moisture has been eliminated—whether it is a leaking wall, poor ventilation, or condensation.
Additionally, I recommend not only storing the doors dry but also checking the cabinet carcasses for any potential moisture-related weak spots, as the issue could otherwise recur. Careful adjustment of the hinges and, if necessary, the use of thin seals can help improve functionality.
dijan
8 Mar 2021 13:37
I think a little trouble with a flush door can actually be a motivation – DIY alert! My recommendation: remove the door, lightly moisten it until it becomes a bit flexible, then carefully secure it with wooden slats and let it dry for a while. Stay patient; this usually works better than you might expect.
For those looking to replace it: yes, Ikea sells doors separately, but try to save the original first – it saves money and is somehow also satisfying.
And: never store the door in a damp room! That’s basically an invitation for warping.
