ᐅ How do you repair stripped screw holes in a Kallax shelving unit?
Created on: 18 Oct 2023 09:37
NICKLAS4
NICKLAS4
18 Oct 2023 09:37
I have an annoying problem with my Kallax shelf: some of the screw holes have become completely stripped due to frequent screwing and unscrewing, so the screws no longer hold properly. I am now looking for a reliable and practical way to repair these damaged screw holes. It is important to me that the repair lasts in the long term and that the shelf can later be mounted securely.
I am open to tips, whether using simple household methods or specialized products from the hardware store. Does anyone have experience restoring the original function of the screw connections in a Kallax without having to replace the whole board? I am especially interested in approaches that keep the effort within a reasonable scope.
Thanks in advance for your help!
V
vinpau
18 Oct 2023 10:12
It’s great that you brought up this topic here! :-) One method I use very often is wood glue combined with wood shavings. Simply mix wood shavings from a small piece of wood with the glue, fill the holes with this mixture, let it dry briefly, then carefully pre-drill again and insert the screw. It holds really strong!
Sometimes wooden dowels or a small piece of wood pushed in can also help if the hole is badly damaged. I encourage you to give it a try—it usually works very well and is quite satisfying to fix something like this yourself! 🙂
CARLA
18 Oct 2023 11:05
Regarding the repair of stripped screw holes in Kallax units, the following methods are recommended:
1. Wood glue and wood shavings: This method is effective for minor damage. The mixture fills the damaged area and allows the screw to be reinserted.
2. Inserting wooden dowels: This is the most stable solution for larger damage. After inserting and gluing the dowel, the hole can be redrilled.
3. Using special repair kits (wood plugs, repair sleeves) available at hardware stores, designed for furniture repairs.
It is important that the area is clean and dry before starting the repair. Additionally, pre-drilling is recommended to avoid further damage to the material.
These methods are practical and ensure a strong connection.
TEBILO
18 Oct 2023 13:47
I would like to go into more detail on this topic, as the typical construction of Kallax shelves consists of particleboard or MDF panels, which are especially sensitive to torn-out screw holes.
Procedure:
1. First, remove the screws and check the actual size of the damage through the damaged hole.
2. For smaller tears, a nearly homogeneous filler can usually be made using a mixture of wood glue and wood dust. It is important that the wood particles are as finely ground as possible to avoid any hollow spaces.
3. After filling, press the area firmly (using a clamp or similar) and allow it to cure for at least 24 hours.
4. Drill the new screw hole at least 0.5 mm (0.02 inches) smaller to ensure secure screwing without additional stress on the material.
5. If the holes are too large, a wooden dowel glued flush is recommended. After curing, the hole for the screw can be re-established with a matching wood drill bit.
One more tip: Do not use a larger screw directly, as this could cause further damage to the material. If the load-bearing area is particularly critical, reinforcing from the inside with a small plate or bracket might be worthwhile.
Can you also say whether the holes are mainly in the side panels or the back panels? Sometimes this makes a difference for the repair.
V
vinpau
18 Oct 2023 14:39
TEBILO schrieb:
Can you specify whether the holes are mainly in the side panels or the back panel?
That’s a great point! If it’s the back panel, often a mixture of wood glue and wood filler works well because the load there isn’t as high. For the side panels, it’s better to use dowels.
CARLA schrieb:
Pre-drilling is important to avoid damaging the material further.
Absolutely, you can’t do anything with Kallax without pre-drilling, otherwise you’ll risk tearing it even more! So always start with a small drill bit, then carefully screw in.
KUDAISY
19 Oct 2023 08:04
I would like to share a simple step-by-step tutorial on how to repair stripped screw holes in a Kallax shelf. I have often used the following method, which has worked reliably for me.
1. Remove all screws from the damaged hole.
2. Clean the hole thoroughly to remove dust and coarse wood debris.
3. Mix wood glue with fine wood shavings or sawdust from similar wood.
4. Completely fill the hole with the mixture and press it firmly in (if needed, use a small wooden stick).
5. Clamp the repaired area tightly (a clamp or a heavy book works as well).
6. Wait at least 12–24 hours for the glue to fully dry.
7. Then drill a new, clean screw hole with a wood drill bit of the appropriate size.
8. Finally, carefully screw the screw back in—do not apply too much force.
Common mistakes include not cleaning the hole properly or insufficient clamping, which causes the filler not to hold well. Also, using screws that are too large, which can damage the material again.
For heavy loads, you can also glue in a wooden dowel, but for simple shelving systems, this method is usually sufficient. Good luck! 🙂
