I have several pieces of furniture at home from the IKEA Hemnes series, which is very practical, but some of the cabinet doors are slightly misaligned or don’t close flush. This is especially frustrating because it doesn’t look harmonious and the functionality suffers.
My specific question is: What is the best way to fix IKEA Hemnes furniture when the doors are misaligned?
I’m particularly interested in the exact steps to properly readjust the hinges or if there are other tricks to get the doors straight and closing neatly again. Is it worth ordering new hinges, or can this be resolved with simple adjustments?
I have already tried tightening the screws slightly, but that only helped to a limited extent. I’m also curious whether material warping due to moisture could be a factor and how to identify this.
Looking forward to your tips, experiences, and advice!
Hello feletu,
I’m familiar with your issue of misaligned doors on IKEA Hemnes furniture. Usually, the cause is the fine adjustment of the door hinges. Hemnes uses simple yet fairly sturdy hinges that can be adjusted using three screws:
- Vertical adjustment: this raises or lowers the door;
- Horizontal adjustment: this moves the door left or right;
- Pressure adjustment: this screw controls how tightly the door presses against the cabinet frame.
It’s important to relieve the door of any weight and roughly align it before making fine adjustments. I would only consider material warping if the furniture is very old or exposed to moisture. If the wooden parts are warped, hinges alone won’t fix the problem—you’ll need to carefully realign the cabinet frame or replace the wood.
Ordering new hinges usually isn’t necessary unless they’re broken or bent. Most of the time, it’s just a simple misalignment. If you need tools like a Phillips screwdriver or possibly an Allen wrench, have those on hand.
Start with small adjustments and check how the door closes after each step.
anken
anken
Hey feletu,
Crooked doors on Hemnes furniture can really test your patience! 😅 What has always helped me is patiently adjusting the hinge screws one by one. Tighten a little, then close the door to see if it fits better.
A small tip: If the door keeps rubbing on one side, also check if the hinges are firmly attached to the frame. Sometimes they loosen over time.
Don’t worry about the screws—you can usually turn them many times before anything breaks. And yes: you rarely need new hinges; the IKEA ones are quite sturdy.
Good luck—and remember, a straight door is essential, otherwise it can really annoy you in everyday use 😄
anken schrieb:
Most of the time, the issue lies in fine-tuning the door hinges.Thanks, anken, that really nails it. Now I know which screws to adjust; I hadn’t considered it so precisely until now.
pakokla schrieb:
Check the spacers to make sure the door isn’t sticking.Good idea, I hadn’t even thought about the spacers yet—I’ll take a look at those right away.
TARAON schrieb:
Also check if the hinges are securely fastened to the cabinet frame.That makes sense, I already noticed one screw had loosened a bit. I’ll tighten it.
I have another question about the order of adjustments: Should the vertical or horizontal settings be done first? Or is it better to keep trying until the fit feels right?
Also: How can you tell if a hinge is defective and definitely needs to be replaced? They usually look pretty much the same on the outside.
feletu schrieb:
Should you adjust the vertical or horizontal alignment first?I always recommend starting with the vertical adjustment. This means aligning the door height-wise so it doesn’t stick or rub at the top or bottom.
After that, you can turn the horizontal screw to shift the door sideways, ensuring the gaps between the doors are even.
Regarding hinge issues: If the door doesn’t stay in place when you open it or if the screws no longer provide resistance and the door sags, this may indicate a bent or worn-out hinge.
Often, it helps to closely observe the hinge to see if it moves too freely or if any metal parts are noticeably damaged. In such cases, replacing the hinge is worthwhile.
Good luck!
