ᐅ How do you repair dents in MALM furniture?
Created on: 15 Mar 2016 08:37
rolenox44
I’ve noticed some dents on the surface of my Malm bed from IKEA that affect the appearance of the furniture. Specifically, these are indentations that don’t look like superficial scratches but more like pressure marks, probably caused by pressure or impacts.
I’m interested in how to best repair such dents on MALM furniture. What methods are available to remove the dents or at least improve their appearance? I’ve considered using heat or moisture, but I’m unsure how that would affect this particular surface.
Perhaps someone here has experience with MALM or similar veneered furniture and can offer advice on the best approach that won’t damage the furniture.
Thanks in advance for your help!
rolenox44
16 Mar 2016 08:50
Thanks for the tips so far!
I have one more question: I’ve read that the steam method works very well for some wooden furniture because the wood fibers swell with water and straighten out. However, since Malm is often coated with a thin foil layer, I wonder if the water might damage the coating or cause stains. Would it be better to only slightly dampen the cloth?
Also, can this procedure be used for small, deep dents, or is it more suitable for broader deformations?
It would be great if someone with experience could explain this in more detail.
manla
16 Mar 2016 09:56
Hello rolenox44,
rolenox44 schrieb:
whether the water might undermine the coating or cause stains?
That’s a valid question. With coatings made of melamine foil – as commonly used on MALM furniture – moisture can indeed be problematic if it soaks in for too long. Therefore, the cloth should only be slightly damp, not wet, and the treatment kept brief.
The steam treatment works best on solid wood; on veneered or foil-covered surfaces, its effectiveness is limited. It raises the wood fibers slightly, but the foil can crack or develop stains if treated too aggressively.
For small, deeply compressed dents, using special repair wax or a furniture touch-up marker can sometimes be more effective. These visually conceal the damage and help protect the surface.
In short: depending on the depth of the dent, you should weigh whether to try the steam method or go straight for gentler repair products.
rotofra
16 Mar 2016 11:40
to pick up and summarize rolenox44’s question:
1. Steam or heat treatment is mainly suitable for dents caused by compressing the wood fibers, and less for vulnerable veneers or laminates.
2. For MALM furniture with a veneer or laminate finish, you should work very carefully, keeping the cloth only slightly damp.
3. As an alternative, repair wax and special touch-up markers that can be color-matched are useful. These help with deeper dents that cannot be smoothed out with steam.
4. A combination is often ideal: first try steam, then if necessary use wax or touch-up markers to improve the appearance.
5. Avoid strong heat and prolonged exposure to prevent damage to the veneer or laminate surface.
6. Finally, apply a fine polish, which often works wonders.
If you decide on repair wax, make sure it is suitable for furniture with veneers or laminates and test it first on an inconspicuous area.
I hope this helps!
